How much boost??
Old Jan 31, 2005 | 12:19 PM
nosdog2's Avatar
nosdog2
How much boost??
How much boost are you guys seeing at idle? And what is the max boost?
Idle ----> 1 1/2 to 2 lbs
MaX ----> 26/27
Old Jan 31, 2005 | 03:22 PM
Daryl Hunter's Avatar
Daryl Hunter
Typically 0 to 0.5 lb. Depends upon whether or not I'm running AC and any other accessories.
Max boost stock was 24.5 lb.
Old Feb 1, 2005 | 11:27 AM
Monster Duty's Avatar
Monster Duty
Are you guys making boost @ idle ?
I don't show anything until I hit around 1300 - 1400 RPM's and that's with a load on the engine .
Am I missing something ??????
Old Feb 1, 2005 | 03:20 PM
Colorado-native's Avatar
Colorado-native
Same here! No Boost until it gets some RPM.
Old Feb 1, 2005 | 04:31 PM
bighoss550's Avatar
bighoss550
MaX ----> 26/27
urs is an 03? mine is and i see 2-3 at idle. 3 if i just come to a stop, then it comes down as it cools.
my max is near 33 just driving. with a good load on a hill with the water on, the boost can touch on the 40psi mark
oops, i just noticed these were all 03's in this thread....... shoots that theory........ haaarrumph
Old Feb 1, 2005 | 05:20 PM
Colorado-native
I'm at 5200 feet and higher. Not as much air to pump up here! Gasp - Wheeze
Old Feb 1, 2005 | 05:33 PM
SBV45's Avatar
SBV45
Just curious, do you have exhaust mods? How about Colorado?
What about the rest of you? I would like to see boost readings at idle with exhaust mods and no mods.
Old Feb 1, 2005 | 05:51 PM
bighoss550's Avatar
bighoss550
my idle readings were the same before and after tyhe straight pipe and the top readings went up no more than 1psi
when i went to the aftermarket filter the idle readings went up 1-1.5 to where they are now
Old Feb 1, 2005 | 05:53 PM
Monster Duty
65 hp Predator , no exhaust or intake . 35" tires and 4250 ft elevation .
Boost gauge tapped into the intake manifold .
Old Feb 1, 2005 | 05:56 PM
SBV45's Avatar
SBV45
So how much boost at idle?
Old Feb 1, 2005 | 05:59 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Hmm...thats wierd, I have never seen boost at idle...
For some reason, mine seems to be gaining .2 to .3 lbs peak per day now...and the turbo keeps getting progressively louder. I doubt it will last much longer No kidding...the turbo noise is getting really, really obnoxious, with no signs of letting off- it has never done this before.
Old Feb 1, 2005 | 06:01 PM
bighoss550's Avatar
bighoss550
do u have anything besides open pipe in ur exhaust? if u have a muffler, the fire ur puttin down the pipe eill probably burn out the stuffing in it
Old Feb 1, 2005 | 06:02 PM
SpartanDieselTech
Former Vendor
Its a straight through muffler, thats not it...it never made this much noise even with a straight pipe. I'm %99 sure the compressor shaft bearings are dying- it makes some wierd vibrations periodically, that are definately coming from the turbo.
Get your butt on yahoo...
Old Feb 1, 2005 | 06:03 PM
Monster Duty
I don't show boost at idle . It starts to show boost when my RPM's are around 1300 and the truck has to be in drive . I'm running a X-Monitor
Old Feb 1, 2005 | 06:08 PM
bighoss550's Avatar
bighoss550
there has to be a small leak in ur line...........
