turbo boost pressure
Old Aug 2, 2006 | 10:24 PM
firemanbird's Avatar
firemanbird
I have a 1995 psd. how mutch boost is it supose to put out at max 3000 rpm??
Old Aug 3, 2006 | 06:34 AM
tjbeggs's Avatar
tjbeggs
my 95 stock puts out 20 psi full throttle empty. 15-18 is pretty average
Old Aug 3, 2006 | 08:10 PM
firemanbird
mine is only putting out about 10 psi. I have a kn air filter down pipe and strait exaust pipe and a super chip programer. My boost needle starts jumping around at 5 psi and gets worst at higher boost levels.
Any one have any ideas. I think i need a new compressor wheel. The truck has lost lots of power.
Old Aug 3, 2006 | 08:23 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Check the intake boots (turbo Y pipe to engine) for splits and loose clamps. Also check the MAP hose and connection. Pull the air cleaner hose and check the compressor blades for dusting.
When the needles is jumping does the turbo sound choppy?
Old Aug 4, 2006 | 08:06 AM
firemanbird
all of the boots and clamps are good. no leaks anywhere. The turbo whistles alot from the intake. but does not sound choppy. the blades dont look dusted ither. could it be the ebpv. and how hard is it to gut it
Old Aug 4, 2006 | 09:08 AM
ltfox's Avatar
ltfox
Check for exhaust leaks on the manifolds and up-pipes to the turbo. A good exhaust leak can hurt a turbo's performance.
Old Aug 4, 2006 | 10:16 AM
Phydeaux88's Avatar
Phydeaux88
EBPV is not to difficult to gut.
Steve Baz has good instructions on his site.
Make sure you check the MAP sensor lines first.
Old Aug 4, 2006 | 08:52 PM
firemanbird
Question
can you give me the link to his website??
Old Aug 4, 2006 | 09:22 PM
ltfox's Avatar
ltfox
http://pages.prodigy.net/stevebaz/_i...az/index3.html
The 94-97 powerstroke Bible!
Old Aug 4, 2006 | 09:37 PM
1997F-350's Avatar
1997F-350
checked your fuel pressure lately? or boost line?
Old Aug 9, 2006 | 10:34 PM
firemanbird
iI am going to put the bb compressor wheel and the bb 100 turbine housing on this weekend and I will hopefully fix the problem or i will at least have the turbo upgrades done.
64ponton
Dec 5, 2007 08:47 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
mcbryant
May 15, 2003 05:49 PM
mcneal
Feb 15, 2001 06:50 PM
