Just curious, do you have exhaust mods? How about Colorado?
No mods - stock with original flash.
There is probably a small positive pressure in the intercooler and manifold, but the gauge (35 PSI DiPricol) probably isn't sensitive enough to show it. Gauge is hooked into the MAP sensor line.
The only time you will see boost at idle on a 6.0 is if the computer is
closing the variable geometry vanes to act as an exhaust backpressure valve.
Other than that, you would have to rev up a 6.0 to see any boost in neutral.
So how much is max boost for an 05 with 65HP predator? I'm only getting 25 or so on factory guage..... Nothing at idle indicated.. else stock..
If the factory gage is like the rest it is not worth much.
Mine is Autometer mine is hooked to the line that goes to the MAP sensor. Mine is a 60 pound gage so it doesn't show much at idle. I tried a vacume/pressure gage first because I had the gage off a blower car. It showed 1-2 pounds at idle.
The most I've noticed is 34 lbs. with a Predator on 65 HP.
Welcome to the 6.0 forum and to FTE. Please take a moment to check out the Welcome sticky post at the top of the forum page as well as the other stickies there. Lots of links to great threads and other information. The search feature works great too
And for your viewing pleasure, check out the link to the Posting and You public service announcement:
