Timing Issues - 302
Old Jul 15, 2008 | 05:40 PM
  #241
BaronVonAutomatc's Avatar
BaronVonAutomatc
Well, if your question is "Will a MAF computer work on a SD engine?" the answer is no.
IIRC, MAF showed up on trucks in 1994.
Old Jul 15, 2008 | 06:19 PM
  #242
ajduby's Avatar
ajduby
my problem
Here it is. I pulled a '94 302 and replaced it with a rebuilt '89 302.
My high pressure pump was not priming, so I wired it direct with a toggle switch. I now have sufficient fuel-pressure to the rail, I have strong spark on all 8 cylinders, but my injectors are not firing.
My last hope is replacing the ecm.
Old Jul 16, 2008 | 04:45 AM
  #243
EPNCSU2006's Avatar
EPNCSU2006
Check to make sure you're getting 12V at the injectors and that the ECM is powering up. Also make sure you have the plug wires in the correct firing order. The 94 probably has the 1-3-7-2-6-5-4-8 order while the 89 (if it's from a truck) has the 1-5-4-2-6-3-7-8 order. It should at least sputter, though, with the wrong order.
Old Jul 16, 2008 | 06:40 AM
  #244
desertdave35's Avatar
desertdave35
Start a new thread and you will get a lot more people looking at it and you will probably get your answer better that way.
51PanelMan
16
Apr 10, 2018 11:08 PM
Jeff Fisher
Apr 17, 2006 09:58 PM
Ford4x4-JD70AB
Jun 8, 2005 08:19 PM
dlowenst
Jan 12, 2005 08:41 PM
black460
16
Dec 6, 2004 05:50 PM
