Any computer/internet gurus wanna provide suggestions?
I have developed a problem login in to certain sites and posting.
What happens in some cases, I will log in, it will thank me listing my username, then the next page will be the login page (?)...keeps going in a circle and I never actually login. In other cases it will thank me for login in, bring up the reply screen, I will type my message hit send reply and it will say your not logged in, I log in, it thanks me listing my username, next page blank reply screen...again a repetative circle. It doesn't do it on all websites but it makes no sense. In one case I registered using a different e-mail address and logged in using the same IE and it works, so that makes no sense. I contacted the administrator of one site and he said the e-mail address or the source of the e-mail address shouldn't make a difference.
Any ideas, as far as, I am concerned nothing has changed setting wise but obviously it must have. I have turned the pop up blocker off and it makes no difference. Any ideas appreciated.
Just a quick idea on this one:
Bad or corrupt cookie information cached for your browser.
You didn't state what you're using to surf the web, but here a few things to try:
Internet Explorer - Tools |Internet Options | Delete Cookies and Delete Files
Firefox - Tools | Options | Privacy - Clear cookies etc there
HTH
HTH
Sounds like you are blocking all cookies. Go to the top toolbar and click Tools> Internet Options> Privacy> Advanced
Choose to ALLOW first party cookies.
Choose to BLOCK third party cookies (these are the ads)
Check the box to Always allow session cookies (this is what's screwing you up).
Oh, this is the method to use if you have IE. I can't help you if you have Netscape or a Linux based browser.
Its netscape.
It was set to accept all cookies.
I delete the cookies on a regular basis, alway have, so that routine never changed/ didn't affect the situation.
On one of the sites that this was happening, the administrator deleted my original account, actually attached my e-mail address (the one I used with the username/password that stopped working correctly) to my new username, all works, so it cannot be settings or at least I don't think so. I am thinking something has affected certains sites but don't have a clue as to were I should begin. Appreciate the replies
Might not help, but you could try running SpyBot S&D http://www.safer-networking.org/en/index.html and Ad-Aware SE http://www.lavasoftusa.com/software/adaware/
and check your system for spyware. You may simply have a trojan installed that's redirecting you, or attempting to.
RR4E
I ran the mcafee if that makes a difference, it found nothing. I followed the link for spybot but ended up with all kinds of links and wasn't sure which one to use.
kingfish51
I haven't recently installed windows XP SP2, I wouldn't know where to turn the windows firewall off even if I did. Any ideas?
kingfish51
If you know a little linux/unix you could download a bootable linux disc, burn the iso to a cd, and boot it up. Then you can run a program called dosfsck to test the hard drive. There is also a anti virus scanner called clam av. The Insert cd has this included, and if your pc is hooked to the net, can download the latest virus signatures online.
Here's some links to helpful cd's:
http://www.inside-security.de/insert_en.html
http://www.tux.org/pub/people/kent-r...looplinux/rip/
These cd's have evolved quite a bit in the last few years, and are really good about automatically recognizing hardware. You will also want to know a little about your hard drive, for instance, they are usually denoted in linux by a HDA1, or HDA2, or HDB1, HDB2, etc... The HDA means the first hard drive in the line, hence the A. The 1 and 2 in the code is the partition. Most cases your hard drive and data will be on HDA1. Some laptops have a partition you don't even see for things like recovery, and in this case your data would be on HDA2.
I am rambling, but these discs can be a lifesaver. I know we have saved a lot of data on servers at my job. And the anti virus saved a laptop just a few weeks ago.
Just in case anyone is interested, here is a list of live linux cd's...
http://www.frozentech.com/content/livecd.php
Isaac
Isaac
Could be the webmaster is not aware of a problem too. I hit the 'register' on one forum type web page and this little iwndow pops up with username and password spaces, so I put in what I wanted for a username and password, then hit enter. It takes me to a page that says I have to be a registered user to do that. Umm, Okayee.
If you have SP2, go to control panel/security settings. Under there you will see how to turn all the new security junk off. And in MS's case I do mean junk. If you do not have another software or hardware firewall, leave it on as it is better than nothing.
Edit: Something else that I remember that happened to me. If you already have a firewall software, go into it's log or settings and make sure it hasn't blocked the particular site used to log in.
Check your browser settings to make sure you are not blocking the cookies from the site or another related site. Sometimes it is not readily apparent which site may be causing the problem.
Isaac
Isaac
yeah you lost me when you posted "If you know a little linux/unix....." .
Aright fellas, were is this firewall blocker everyone mentions, gonna have to spoon feed it to me. Thanks
3broncocrazy
08-29-2007 06:02 AM
pancake
10-28-2005 12:51 AM
99 ranger bob
27
04-06-2004 10:11 AM
