Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
shop lighting
Old Nov 11, 2004 | 09:05 PM
  #91
Fritolay's Avatar
Fritolay
if you are willing to go the cheap and efective route every walmart ive been in has 48" dual bulb fixtures for $5 each and you can get ten packs of bulbs for like $8 i helped my dad wire them up in the shop that he just built and they are plenty bright and he has i think an eighteen or twenty foot ceiling.
Old Nov 12, 2004 | 03:02 AM
  #92
maverick man's Avatar
maverick man
they probrobly aren't very bright when the temp drops below 30 degrees. that's the problem i've had with lights like them in the past....
Old Nov 12, 2004 | 06:57 AM
  #93
wtrguy's Avatar
wtrguy
lights
they are cold weather set up.Think they have a different ballast in them. Have heat out there that we turn on just when we are out there.With the two kinds it works well
Wtrguy
Old Nov 12, 2004 | 10:52 AM
  #94
zuikoman's Avatar
zuikoman
Not only is the brightness an issue with the regular ballasts in cold weather, you wont even be able to turn them on when it gets cold enough. A lot of the cheap ones barely work at room temp. I've used the HO fixtures below zero and they still work.
Old Nov 12, 2004 | 12:01 PM
  #95
jjshaw's Avatar
jjshaw
Another thing I've learned from (finally) doing a little research is that the electronic ballasts reduce both flicker and hum to a very low level. If you're going to spend a lot of time working under these lights, as I am, then that's a pretty big deal.
superv10
Arizona Chapter
Oct 8, 2014 08:36 PM
1saxman
2004 - 2008 F150
Nov 5, 2013 03:07 PM
dfs
Apr 4, 2011 10:33 PM
03silverTJ
Apr 25, 2010 09:25 AM
77bigblock
28
Oct 12, 2007 11:26 PM
