brake controller
Old Sep 27, 2004 | 07:38 PM
hoofer's Avatar
hoofer
brake controller
i have a 2003 f259 sd crew cab 4x4 diesel and want to connect my energize III electric brake controll that came with my fifth wheel i have the factory plug from ford but not the manual for the brake controller there are four wires on the controller and five with the factory plug could anyone help me out with this ??got most of it figured out but want some confirmationi think the white is ground red is stop lamp indicater on controller blue for the brakes black for 12 volt feed ??
help please..........
Old Sep 29, 2004 | 08:37 AM
Cowboy Brett's Avatar
Cowboy Brett
It doesn't have all the wires tagged for you? Mine had little tags that told you what everything did. No matter.
If you have the one that came with the truck, you've got 5 wires of the following color and assignment:
Dk. Blue: Brake Controller Output (to rear of truck)
White: Ground
Green: Stoplight switch signal
Red: 12V Battery power
Brown: Dimmer control
The wire you'll be missing on the controller will be the dimmer. I'd just tape it up.
For future reference for y'all, tekonsha has the assignments of wires on the website here:
http://www.tekonsha.com/files/BC%20W...20Rev.%20A.pdf
You'll need Acrobat for this, but it covers both the old and new ford harnesses.
Old Oct 12, 2004 | 06:32 PM
FFsmo's Avatar
FFsmo
hey cowboy, if im reading this link right red on the harness goes to black on the controler and so on. Ive got an 04 f250 with the harness but an old tekonsha controler, also with no diagram. Any help would be appreciated.
Old Oct 20, 2004 | 08:30 AM
Cowboy Brett
I don't think Tekonsha has ever changed their harnesses on their end. Ford has at least three harnesses. An 04 ought to have the six-pin grey connector under the removable panel beneath the setterring column, off over towards the center of the truck. That one has the green wire as the brake switch.
Does Tekonsha still make the model you have? I know they have the Prodigy, Voyager, and Sentinel units.
Apparently, the brand new ford harnesses for the f150 has a different wire combination. Older big (250 and higher) F-series used a four pin harness with different wires.
Old Oct 20, 2004 | 11:47 PM
FFsmo's Avatar
FFsmo
I called there teck support. It sounds like all there controlers wire the same, they set me straight in about 15 seconds, it took me about an hour on the other hand to figure out were to mount the dang thing.
Old Oct 21, 2004 | 11:10 AM
Cowboy Brett
I put mine down next to the sunglass holder, above the 4x4 lever.
windindaface
Dec 21, 2012 01:22 PM
1979F-150Man
Mar 14, 2012 12:30 PM
wileyeyejeep
Feb 25, 2012 08:42 AM
Frankievespa
Apr 11, 2011 09:56 PM
TheTowingCowboy
Mar 28, 2010 11:46 PM
