Sponsored by: Real Truck
Brake Controller
Old Mar 13, 2012 | 07:49 PM
1979F-150Man's Avatar
1979F-150Man
Brake Controller
Hello- I have a 2000 F250 and I want to install a brake controller. Under the panel I believe there is a box I can plug a controller harness into. I have a Power Stop 500 PS that I really like. Do they make a harness I can plug into the factory brake controller wiring and splice into my Power Stop box?
Old Mar 13, 2012 | 08:59 PM
Kajtek1's Avatar
Kajtek1
There is a plug behind cover below the radio and the trucks do have harness in the glove box when they leave the factory. Some controllers have available plugs that fit directly in the truck plug.
Don't forget to make sure you have fuses for trailer installed in the box under the hood.
Old Mar 14, 2012 | 10:45 AM
TexasRebel's Avatar
TexasRebel
There was no factory brake controller in 2000.
The wiring you found is for exactly what you are describing.
Some controller manufacturers will offer vehicle specific harnesses. If yours doesn't, Ford offers a "blunt to truck" harness that will fit the connection you found.
Old Mar 14, 2012 | 12:08 PM
Bigpipes 35's Avatar
Bigpipes 35
Yes they do make one , you can get one at your ford dealer or most auto parts stores have them as well..
Old Mar 14, 2012 | 12:30 PM
dkf's Avatar
dkf
Only thing I saw available for the particular controller you list is a single ended pigtail that still needs to be wired to the controller. I bought a ready made harness for my tekonsha P3 for like $10 which had a plug to the controller on one end and a plug to the truck on the other end. It was just plug and play. Tekonsha is a pretty common brake controller company though. My 04' came with a pigtail that plugs into the factory plug under the dash but I bought my truck new. A used truck usually is missing things like that.
This link is on an 06' but some may apply to your truck.
http://www.etrailer.com/question-8256.html
kickstand03263
All Things Towing
Feb 7, 2013 12:40 PM
wileyeyejeep
Feb 25, 2012 08:42 AM
mblanken881
Jan 10, 2012 08:06 PM
MRUGG
May 8, 2010 05:41 PM
blockmanjohn
All Things Towing
Feb 10, 2008 06:08 AM
