Sponsored by: Real Truck
Factory Brake Controller
Old Dec 20, 2012 | 03:45 PM
windindaface's Avatar
windindaface
Question Factory Brake Controller
Just bought my 06 SD and someone has installed an aftermarket brake controller because the OEM doesn't work. I would like to go back to the OEM but will need a controller and the 4 pin plug( or harness) does anyone have one?
Old Dec 20, 2012 | 04:10 PM
maverick22's Avatar
maverick22
First off, how did they install the aftermarket? Did they hack into the plug for the OEM controller or wire it in separately? It could be as simple as unplugging the aftermarket, getting a new OEM controller and plugging it in, or there could be more wrong.
You can buy a new controller from Ford or go the salvage yard/ebay route. I'll warn you they're not cheap to buy new but they do work very well.
Old Dec 20, 2012 | 04:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
Was the truck originally equipped with a factory TBC? If not, you will also need to install a new master cylinder and get the feature turned on in the PCM.
Old Dec 20, 2012 | 04:32 PM
windindaface
they cut the oem plug off. I guess I will need to go the salvage yard route for the harness.
Old Dec 20, 2012 | 04:34 PM
windindaface
yes it came with factory controller. I was basically trying to find a harness to replace the cut one.
Old Dec 20, 2012 | 05:17 PM
maverick22's Avatar
maverick22
Ouch. That kind of thing bugs me, not a fan of hack jobs. You can probably go to Ford and get the pigtail and just splice the wires back together cheaper than you can find a whole harness. I'm not sure how far back it plugs in.
I'll warn you, the OEM controller can be plagued w/ annoying alerts and messages, that's probably why the previous owner took it out. Mine has a continual TBC fault but it still works fine, hopefully yours will work when you get it hooked back up. Keep us posted!
Old Dec 20, 2012 | 05:40 PM
windindaface
thanks for the info
Old Dec 20, 2012 | 08:42 PM
SC_Hoaty's Avatar
SC_Hoaty
Do they have those pull-a-part junkyards in your area? If so, you might be able to get the factory controller and the connector in one visit - cut the wires and take the unit and connector attached.
Keep us posted on how it turns out, please.
Old Dec 21, 2012 | 05:24 AM
m350's Avatar
m350
Yep,,what SC_Hoaty said, call around to your local Car salvage yards,,My 06' F-350 recently had a Brake controller acting up,,,,was siting in driveway in Park,,,controler was Beeping and Gain lights lighting up Blinking,,,New Ford contoller was $380 plus tax,,,salvage yard was around $160,,did not need the Harness,,,the Controller Just fits in the Dash with Friction,,,need to reach behind push and Pull from front and back,,,will come out ,,,,Good luck!
Old Dec 21, 2012 | 01:22 PM
windindaface
thanks for the info. I might just stay with the aftermarket controller
dnewton3
Apr 8, 2018 05:58 PM
ssandirene
2015 - 2020 F150
Apr 8, 2016 06:33 PM
RBALAN
Mar 23, 2013 07:30 PM
duckhunter 51
2009 - 2014 F150
Jul 20, 2012 10:14 PM
guthrie&co
Jan 21, 2010 08:25 AM
