i have a 2003 f259 sd crew cab 4x4 diesel and want to connect my energize III electric brake controll that came with my fifth wheel i have the factory plug from ford but not the manual for the brake controller there are four wires on the controller and five with the factory plug could anyone help me out with this ??got most of it figured out but want some confirmationi think the white is ground red is stop lamp indicater on controller blue for the brakes black for 12 volt feed ??
help please..........
hey cowboy, if im reading this link right red on the harness goes to black on the controler and so on. Ive got an 04 f250 with the harness but an old tekonsha controler, also with no diagram. Any help would be appreciated.
I don't think Tekonsha has ever changed their harnesses on their end. Ford has at least three harnesses. An 04 ought to have the six-pin grey connector under the removable panel beneath the setterring column, off over towards the center of the truck. That one has the green wire as the brake switch.
Does Tekonsha still make the model you have? I know they have the Prodigy, Voyager, and Sentinel units.
Apparently, the brand new ford harnesses for the f150 has a different wire combination. Older big (250 and higher) F-series used a four pin harness with different wires.
I called there teck support. It sounds like all there controlers wire the same, they set me straight in about 15 seconds, it took me about an hour on the other hand to figure out were to mount the dang thing.
