292 Auto tranny ??
Old Sep 19, 2004 | 03:34 PM
OldSchoolRodz's Avatar
OldSchoolRodz
Wink rlangs58 confused himself for dantudor57
Yes Ron, it seems "for some reason some of these threads get a
little tweeked now & then". Please observe the Post imediatly behind mine I was responding to. Note that dantudor57's name is Dan, then check his user profile for an understanding of where I came up with California. Hey Dan, I'll try to E- you directly to uncomplicate this. David
Old Sep 20, 2004 | 07:32 PM
dantudor57's Avatar
dantudor57
Question
Things do get a little complicated, don't they?
From this thread, I have the following understanding (please correct me if I am wrong).
Yblocks are mounted differently in trucks than cars. In cars the engine block is mounted to the frame using two motor mounts, one on each side of the block. On trucks, the engine is mounted using three mounts, a mount on the front of the engine (timing cover mounted), and the mounting horns on the bellhouing. Engines in trucks are not mounted using the engine block mounts as used in cars.
Is this correct?
Old Sep 20, 2004 | 07:47 PM
pcmenten's Avatar
pcmenten
Yes, you have it pretty much right. I will qualify the statement by saying that T-birds and some other cars (like my 56 Fairlane) had front 'engine rests', but it is essentially right to say that cars use engine mounts on the sides of the block and trucks use engine mounts that are on the bellhousing.
truckman87
Jun 9, 2012 02:04 PM
f700
Engine Swaps
Jul 2, 2007 07:54 AM
mrblottokid
Mar 29, 2004 05:41 PM
64y292
Aug 25, 2002 02:58 AM
Nathan
Sep 25, 2000 01:33 PM
