i have a question
Old Mar 25, 2004 | 04:35 PM
mrblottokid's Avatar
mrblottokid
i have a question
i have a 64 ford f250 with a 292 with a 4 speed and i was wondering if any one else has a 292 with a 4 speed in their in there truck and what kind of gas mileage u guys get if someone does have a 292
Old Mar 26, 2004 | 08:59 AM
Mike G's Avatar
Mike G
Sorry I don't have a 292 (a 65 352 though) but can't imagine you would get any better than around 15mpg out of the 292.
--Mike
Old Mar 26, 2004 | 03:12 PM
BigFord1977's Avatar
BigFord1977
Mike, I have the same (65 with 352 4 speed) what are you gettin MPG?...ill tell ya i haven't figured mine out yet but its not good at all..
Old Mar 26, 2004 | 04:04 PM
Mike G's Avatar
Mike G
Mine has only gotten me around town lately as it is not licensed with current plates so i have not actual mpg numbers. The .060 over 390 in being put together and I should be truly road worthy in a few months... I am anticipating somewhere in the 12-14 range
--Mike
Old Mar 27, 2004 | 12:13 AM
motorcyclist's Avatar
motorcyclist
My 64 F250 also has a 292 with the warner T98 4 speed, have got as high as 14, average about 11mpg.I would like to change the rear end from the 4.11 to a 3.73 to see if improves much.
Old Mar 28, 2004 | 01:43 PM
mrblottokid
thanks im geting like 6.5 to maybe 8 miles to the gallon right now
Old Mar 28, 2004 | 09:34 PM
motorcyclist
I dont know what type of driving you do, but that sounds a bit excessive fuel consumption, have you looked at your plugs to see if it is running too rich, also check your ignition timing. If it is too retarded it can increase fuel consumption and reduce power, also check to see that your choke is not part closed.
Old Mar 29, 2004 | 05:41 PM
mrblottokid
thanks i dont drive it hard and i am defenitely running to rich i am not sure how to adjust my carb just yet though and i dont have the equipment to check the timing but as soon as i get some extra cash i will have it checked
Shortys
Feb 2, 2010 11:51 AM
spivey1
Dec 24, 2008 08:52 AM
Rellim51
Aug 20, 2008 04:37 PM
trac292
Apr 29, 2006 08:58 PM
Brad 61
Jan 9, 2005 09:35 AM
