Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Which torque wrench?
Old Sep 25, 2004 | 08:26 AM
  #31
hot1958's Avatar
hot1958
there is a tool called a torque stick,that can be used on an impact wrench that applies a set amount of torque.they are color coded for diff.torque value's,maybe that is what your tire store use's.you should torque your wheel's,like plilikoi said .to keep from warpping your rotor's.if you have alum. wheel's you should retorque your wheel's after about 4 or 5 day's,to make sure they are not loose again.alum.is soft,and will move around,and could loosen up again.
Old Sep 26, 2004 | 08:03 AM
  #32
2003 6.0's Avatar
2003 6.0
Most of the shops in my area say that alum. wheels need retorqued after just 25 miles. I've also seen in some owner's manuals that say to drive 100 miles. I prefer to do it at 25 miles. I'd never want a wheel to come off going down the highway.
Old Sep 26, 2004 | 11:04 AM
  #33
Beechkid's Avatar
Beechkid
Torque Wrench
Well, I showing my age here but I ahve a Bonney brand torque wrench (snap type)...excellent tool, never a problem (for 20+ years)...yes I have it recalibrated just befor an engine build.
Old Sep 26, 2004 | 12:09 PM
  #34
srod's Avatar
srod
I have a craftsman 1/2" beam also, it's worked well for me over the years, broke it once and Sears replaced it for free
GM4WALLS
20
Sep 22, 2014 07:14 AM
One Sock
Jan 25, 2011 06:24 AM
Hangfire
Garage & Workshop
18
Jul 29, 2005 12:16 AM
midlf
Garage & Workshop
33
Jan 26, 2005 06:10 AM
Fordman65
Garage & Workshop
Sep 27, 2003 12:02 AM
