General Automotive Discussion
Formula 1
Old Mar 6, 2014 | 05:11 PM
  #901
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
'They' are creating downforce to hold the wheels on the ground.
'They' have a lot of $$$, computer simulation and wind tunnel time making sure it is optimized.
I'm not sure what the flex rules are now, but in the past control surfaces would load to a point and then spill. (because, 'no active aerodynamics')
Merc innovated air bleeds within the chassis.
The front wings have a lot less elements this year.
Old Mar 6, 2014 | 05:53 PM
  #902
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Dove tailing what Jim said..this is the most technically advanced hybrid in the world
Future vision: Engineers discuss 2014 changes 15 Aug 2013
The 2014 season will bring with it some of the biggest changes to Formula One racing’s technical regulations for quite some time. Not only is the sport adopting new 1.6-litre turbocharged V6 engines, there are also tweaks to the rules concerning aerodynamics and a far greater emphasis on energy recovery systems. We spoke to two technical directors - Toro Rosso’s James Key and Caterham’s Mark Smith - about the new regulations and what effect they’ll have on the design of next year’s cars, but first, here is a summary of the main changes:
Engine - it’s out with 2.4-litre normally-aspirated V8 engines and in with 1.6-litre V6 turbo engines, revving to a maximum of 15,000rpm. The current engines produce more than 750bhp, whilst the 2014 units will produce around 600bhp with additional power coming from Energy Recovery Systems (see below).
Gearbox - gearboxes are to have eight forward ratios - rather than the current seven - which each team must nominate ahead of the season.
Energy Recovery Systems (ERS) - in 2014, a larger proportion of each car’s power will come from ERS which, together with the engine, make up the powertrain or power unit. As well as generating energy under braking, ERS units will also generate power using waste heat from the engine’s turbocharger. Unlike the current KERS - which give drivers an extra 80bhp for six seconds per lap - the 2014 ERS will give drivers around 160bhp for 33 seconds per lap. To compensate for the extra power being generated under braking by ERS, teams will be allowed to use an electronic rear brake control system.
Fuel - to promote fuel efficiency, fuel will be limited to 100kg per race. At the moment fuel is unlimited, but teams typically use around 160kg per race.
Minimum weight - to compensate for the increased weight of the 2014 powertrain, minimum weight has been increased from the current 642kg to 690kg.
Exhaust - unlike today where two exhaust tailpipes are used, the 2014 regulations mandate the use of a single tailpipe which must be angled upwards to prevent the exhaust flow being used for aerodynamic effect. Additionally, bodywork is not allowed to be placed behind the tailpipe.
Nose height - for safety reasons the height of noses will be reduced in 2014. The maximum height is currently 550mm, whereas next year it’s 185mm.
Front wing - front wings will be a little narrower next year with the width reduced from 1800mm to 1650mm.
Rear wing - the rear wing will also look a little different in 2014 compared to this year’s models. The lower beam wing is being outlawed and the main flap will be slightly shallower in profile.
Old Mar 6, 2014 | 05:54 PM
  #903
IB Tim's Avatar
IB Tim
VERY good article
How Formula One's Amazing New Hybrid Turbo Engine Works
.....and then the best
http://www.wired.com/autopia/2014/01...guide-f1-2014/
Old Mar 6, 2014 | 06:42 PM
  #904
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Too bad Wired featured the Renault that RB is having so many problems with this year...
Or are they just sandbagging?
15k rpm limits are a farce.
This is F1, piston speed should be the limiting factor.
22,000 anyone?
Old Mar 6, 2014 | 06:43 PM
  #905
Greywolf's Avatar
Greywolf
All of this is going to take a while to absorb -
THAT IS A LOT of tech...
Old Mar 6, 2014 | 06:51 PM
  #906
Bdox's Avatar
Bdox
Wolfie, I know everything has changed as of this year. But you ARE right about the drag created by the aerodynamic "aids." Or so I have read.... at 200kph, if an F1 driver lifts completely, he will experience around 3.5 G of drag. Any street car could not achieve that rapid a stop slamming both feet on the brakes.
Old Mar 6, 2014 | 06:54 PM
  #907
Bdox's Avatar
Bdox
I agree Jim. I think that is sacred ground where rule makers should be ruled out!!!
If a team can build an engine that will stay together, get those angels out of the way, no limit on rpm.
Old Mar 6, 2014 | 06:59 PM
  #908
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There's already a fuel limit on the race.
RPM's will be limited by the ability to finish.
Let those puppies stretch their legs.
Old Mar 6, 2014 | 07:22 PM
  #909
SteveBricks's Avatar
SteveBricks
FTE Emeritus
Anybody have the slightest clue what the liquid measure of 100 kilos of F1 fuel is?
Old Mar 6, 2014 | 08:47 PM
  #910
IB Tim's Avatar
IB Tim
100 liters = 26.4172051 US gallons
Damn little fuel for that much HP and that long of a race...1.5 hours not a fuel stop...it really is very impressive
Old Mar 6, 2014 | 08:56 PM
  #911
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A liter is one kilo only if pure water @4*C.
Or the fuel has a SG of 1.
Gasoline is somewhere under .75
http://www.engineeringtoolbox.com/sp...ids-d_336.html
Old Mar 7, 2014 | 12:19 AM
  #912
BigF350's Avatar
BigF350
FTE Emeritus
Originally Posted by Greywolf
They seem to be playing with the front spoilers a great deal - and in ways that may not be immediately apparrent.
The more stuff they have out front - the more resistance they must have.
That much CRAP out in the front just doesn't seem very efficient to me - what the hell are they trying to accomplish?
IF THEY ARE ATTEMPTING TO STICK IT TO THE ROAD BETTER, IT MUST MEAN THEY HAVE A RATHER DRAMATIC AMOUNT OF ENERGY TO JUST THROW AWAY...
I seriously wonder what all of that costs in terms of the top speed end of the business?
And yet - the stange shapes of the many spoiler components must have been designed to smooth out the flow over the suspension parts.
It still looks very bizarre
The front nose regulations changed to prevent this:
(the idea is to keep the nose low enough, so the car doesn't run up over the rear tires)
22,000 anyone?
I agree, the BMW's were cracking 19,000 rpms on the old V10's in qualifying.
That said, for fuel conservation I heard most teams will be upshifting at 12-13k this year during the race.
Its pretty much 36 gallons.
Old Mar 7, 2014 | 06:00 AM
  #913
IB Tim's Avatar
IB Tim
Adrian am I off on 100 liters equals 26 us gallons or is that imperial gallons ...or fuel will be limited to 100kg per race. and that is where I got it wrong
I am off on my Kg to litter conversion..maybe that is why I got off on the wrong math "path"
So it is 36 gallons
Old Mar 7, 2014 | 09:27 AM
  #914
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is there a 'spec' fuel now?
Does everyone draw from the same drum?
I thought fuels were submitted before the race and a sample drawn at race end to make sure they jibed.
Teams were allowed to 'run what they brung' as long as their formula fit within the rules laid down by FIA.
Old Mar 7, 2014 | 10:50 AM
  #915
BigF350's Avatar
BigF350
FTE Emeritus
So it is 36 gallons
Yup, thats where you are off - if it was water, you would be pretty close to accurate, but the specific gravity of petrol at room temperature is around 730g/L
There isn't a "control fuel" per say, supplying your own fuel is still the responsibility of the teams, but there are tight regulations on what the fuel can be.
Essentially it has to have less than 102 RON (this would be about 97 octane on American pumps), and it can't contain anything in it that isn't in a normal fuel that you can buy at the pumps (although the composition might be different).
At the end of qualifying/race each car has to have 1 Litre/quart left in the tank so the officials can do random audits to confirm the fuel they are using meets these standards. This is why in recent years a number of cars have not driven back to the pits at the end of the race/qualifying as the teams were running as little fuel as possible and got so close to the final quart, that they just parked the car on the side of track as soon as they crossed the line. This was a grey area in the regs - this year, the car must make it back to the pits under its own power and still have the litre/quart left in the tank.
