SC Update II
Old Feb 27, 2004 | 09:59 PM
V6Mustang's Avatar
V6Mustang
I'm not familiar with all of your mods so list them and I will take a guess
I'm glad you finally got it up and running man!
Old Feb 28, 2004 | 12:14 AM
charles6's Avatar
charles6
Hey man, a bet your just antsy to get that thing up and running, congrats! I've got another question for you, do all s/c come w/a blowoff valve(I just love the way they sound)? I wish I was in your shoes right now.(very soon my friend, very soon) There is a guy can't remember who it was but he made a custom s/c kit for his 99 4.2l and he had 330rwhp! I don't know what other mods he had though.
thanks,
Brad
Old Feb 28, 2004 | 08:14 AM
true4.2's Avatar
true4.2
His mods are:
Gibson SISO exhaust
JBA headers
TB Spacer
Supercharger
....and a future intercooler
Is that all of them? (besides the sound system that is)
Old Feb 28, 2004 | 09:25 AM
SkinnyNate's Avatar
SkinnyNate
Hey Garrett,
Did you ever get the last pick I sent you for belt routing?
I had a problem with my belt at first too. The bolt for the top SC idler was just a little to long and it caused my belt to slip also. But in my case it sliped forward and cut through my $216 AC hose. (nice to have a Ford Mech for a friend! cost me nothing) Any way, I just put a small 1/8" spacer on the bolt. It works fine know.
Where are you getting your after cooler from? and how much dose it go for?
Charles6,
It dose have a small blow off valve. Although you can't really hear it.
Old Mar 1, 2004 | 01:54 AM
horizonhuskies's Avatar
horizonhuskies
Yeah Joe..thats them. The volant and chip are sitting peacefully on the shelf.
I got the install complete, and learned my battery was toasted. LMAO. I went out and bought a new one, but dont feel the truck is running right. It lags some, almost like it wants to die sometimes. I will re-check the plugs, and make sure they are what I need in my application now. I didnt check in the first place and I should have. The intercooler I found on eBay. do a search for intercooler spearco and see what you get.
Garrett
Old Mar 1, 2004 | 02:51 AM
V6Mustang's Avatar
V6Mustang
Does it only do it when you see boost? Or does it do it even when taking off normally? What are your plugs gapped to?
How much boost are you running? If you're running 10-12psi I think you'll pull ~270rwhp/~290rwtq
*Edit - I totally guessed on the torque. A lot of stangs with near stock motors and a supercharger make about 280 torque at the wheels so you will probably see more. For comparison purposes.. A 2001 3.8L 5-speed. Vortech V2-SQ @ 13 psi, Fordchip, 36# injectors, 75mm Pro-M MAF, 255lph fuel pump, MAC high flow catalytic h-pipe, dual exhaust with Flowmaster 40 series, Jacobs Wires, FMS AWSF22C plugs
He pulled 287.3/289.7
Dyno Graph
So here's to hoping that your estimate of 267 and mine of 270 are low!
Old Mar 1, 2004 | 07:21 AM
Busa01's Avatar
Busa01
What type of plug does the kit call for? You can't use your Volant now??
Old Mar 1, 2004 | 09:43 AM
horizonhuskies
Actually, it does it after I put the clutch in while rolling. I idle normally, with no problems. I dont remember the exact plugs it calls for, but I am gonna double check them tonight when I get home.
"*Edit - I totally guessed on the torque. A lot of stangs with near stock motors and a supercharger make about 280 torque at the wheels so you will probably see more. For comparison purposes.. A 2001 3.8L 5-speed. Vortech V2-SQ @ 13 psi, Fordchip, 36# injectors, 75mm Pro-M MAF, 255lph fuel pump, MAC high flow catalytic h-pipe, dual exhaust with Flowmaster 40 series, Jacobs Wires, FMS AWSF22C plugs"
Those are some nice mods to the stang. I am sticking with mine for a bit. I dont want to upgrade before I even get the darn thing running right. I should be running at or about 6 PSI, but I have yet to go WOT, due to the hesitation feeling. I want to insall the AF and boost gauges I got from a guy at got-pressure. On top of that, my steering is a little tight...I can hear a slight squeal when I do turn slowly. Its kinda weird. Thinking about the RPM thing, it only happened after I punched the gass a little...heh...It sounded soooo COOL though. To hear the SC dump the air is AWESOME. I will keep all updated.
Old Mar 3, 2004 | 08:53 PM
horizonhuskies
Yet another setback.....Let this be a lesson to all:
I order the spark plugs by someones reccomendation. I figured since they were good in the area of superchargers, they knew what plug I needed. So without checking my plugs first, I ordered AWSF22Cs. They have a 4 thread head. The motorcrafts I pulled out are AGWF34E.....8 thread....Needless to say I have the wrong spark plugs, because I didnt take the time to verify the plugs I already had.
Garrett
Old Mar 4, 2004 | 07:25 AM
Busa01's Avatar
Busa01
Garrett, Did you try installing the plug???
Important note: How many threads you see on the outside of the plug does not matter one single bit. Your plug does NOT thread in all the way anyway. It could have 500 threads on it and will still stop where it's supposed to, you'll just see some thread sticking out of your motor where the plug is.
My Autolite 764,s were like that. They only had like 3 rows of thread, but still threaded in all the way and worked perfect. When I dumped the nitrous and picked up a standart platinum set of Autolights, they had like 15 rows of thread, but the plug still threaded in the same amount, and they work great.
don't worry about the threads, it's misguiding. Only way to really tell is to screw them in and start her up. Try it.
tom
Old Mar 4, 2004 | 08:19 AM
BrianA's Avatar
BrianA
Tom
I do not understand. Are you saying that you installed your spark plugs, they tightened down fully, but there was still thread exposed above the top surface of the plug hole in the head?
If that is the case, what stopped the plug from going in any further?
What did it, in essence, "seat on"?
I have never seen plugs tighten down and still have thread showing.
Something seems amiss here.
In essence, what I am saying is the length of the threaded portion can vary, but all of the threads should be screwed into the head and the plug torqued down against the top of the plug hole in the head.
Old Mar 4, 2004 | 08:32 AM
Busa01's Avatar
Busa01
Yes Brian that is what I'm saying. I believe the threads were flanged, only allowing me to screw them in a certain amount. I've seen two types of plugs, one type has a seating washer on it that crushes when you tighten down the plug. On the outside of the plug box, it will list 2 different torque requirements for each type of seated plug. there are flanged plugs, and then there are crush washer seated plugs. Flanged plugs are supposed to be hand tightened and then turned only 1/8 turn after that and crush washer seated plugs are 1/2 turn after seat, I believe.
GARRETT, I is important to note that when you are running a power adder, be it nitrous or an SC, you need to run a colder plug.
Colder plugs WILL NOT extend as far inside your cylinder as normal temp plugs, therefore it is perfectly normal for your colder plugs to have less threads. It is the intention of the plug to seat more shallow in your cylinder.
If your unsure, Autolite 764's are proven tried and true. Just about every single high performance mustang out there uses them. They are 2 full steps colder than your stock plug and are not platinum. They too have less threads on them than the stock plug.
Install the plugs and start the truck. The colder plugs will also reduce gas mileage, price paid for power.
Tom
Old Mar 4, 2004 | 09:32 AM
  #28
horizonhuskies
The main problem I had was not being able to see. My engine compartment is so snug, I couldnt tell you how well the stock ones sat. On top of that, I was told the AGSF32Cs have the 8 threads....I dunno...Im just gonna say to heck with it, and install and see....If they dont work, I will just eat the 20 dollars.
Garrett
Old Mar 4, 2004 | 09:39 AM
  #29
Busa01's Avatar
Busa01
20 bucks? My plugs were only 1.29 each.
tip: remove your front tires and access the plugs from the wheel wells. Take you 5 minutes to change your plugs from this angle, and the view is unubstructed!
Tom
Old Mar 4, 2004 | 10:36 AM
  #30
horizonhuskies
6.29 for the plugs, then tax and shipping fees. Lame. LoL. I will just call ford and buy it from them. Just to be on the safe side.
Garrett
