Originally posted by steveo420 It fails at the yoke.
Check the fit of the cup. Make sure that each cup sits snug against the end stops. Most of the time when a joint fails at the yoke, the yoke is worn out.
Your cups should fit snug - no slack.
Also make sure the yoke is not wobbling on the pinion shaft. This will create undue pressure on the u-joint.
