u joint problem
Feb 24, 2004 | 10:34 AM
u joint problem
I have a 1977 F-250 highboy and can't keep a u joint in the rear of the main shaft . Please help!!
Feb 24, 2004 | 10:39 AM
Are you keeping it greased? Do you have the truck lifted?
Does it fail mainly in the shaft or the yoke? Is your truck lifted?
Feb 24, 2004 | 10:42 AM
It fails at the yoke.The ujoints are HD nongeaseable,the truck has no lift
Feb 24, 2004 | 10:55 AM
Quote:
Check the fit of the cup. Make sure that each cup sits snug against the end stops. Most of the time when a joint fails at the yoke, the yoke is worn out.
Your cups should fit snug - no slack.
Also make sure the yoke is not wobbling on the pinion shaft. This will create undue pressure on the u-joint.
Feb 24, 2004 | 11:30 AM
what are you doing when it fails?....the stock 4 inch rear blocks create a good bit of axle wrap.......
Feb 24, 2004 | 04:19 PM
The yoke has some bearing play and the yoke it self is a mess(alot of breaks)
Feb 24, 2004 | 04:27 PM
Now you know the problem.
I bet you can get those at a junk yard. There are a few driveshaft shops here that sell them for a fairly good price. Northeast Texas that is.
Feb 24, 2004 | 05:13 PM
thank's for the help i'll rebuilt the 205 and get a new yoke
gene17847
Jul 29, 2008 10:28 PM
dantsg
1997 - 2003 F150
Apr 12, 2008 12:21 AM
Ryan50hrl
Apr 22, 2002 09:10 PM
77 steve
Dec 4, 2001 08:48 PM
PAUL_2
Apr 27, 2001 09:02 PM
