Sponsored by: Auxito
U-Joints
Old Apr 10, 2008 | 10:54 PM
dantsg's Avatar
dantsg
U-Joints
Is there an expected life span for the U-joints / driveshaft?
Old Apr 10, 2008 | 11:26 PM
Club Wagon's Avatar
Club Wagon
How gentle or severe the service U-joints are exposed to has much more to do with their "expected life span" than miles or years. Driveshafts tend to be extremely durable & most replacements are from getting banged up, not wear.
Old Apr 11, 2008 | 06:47 AM
Ron W.'s Avatar
Ron W.
Also affecting the life span of the u-joints is whether or not they are grease-able and if they actually get lubed at every oil change.
Old Apr 11, 2008 | 05:09 PM
steve(ill)'s Avatar
steve(ill)
your talking about a F150- in general i would guess 50% of the rear drive shafts get new universal joints at about 100k miles. The front shaft goes longer since it is seldom used under load.
Old Apr 11, 2008 | 07:23 PM
40LUTZAG's Avatar
40LUTZAG
u joint removal
do you have to take off the bolts off that hold the driveline. or can you just use needle nose to take th u joint off.
Old Apr 12, 2008 | 12:21 AM
Club Wagon's Avatar
Club Wagon
If you're contemplating DIY U-joint replacement I strongly recommend that you obtain a Haynes or Chilton manual & go over the procedure 1st.
None of us are mind readers, your Q is leaves much unanswered. The short answer is both, however there's a LOT MORE to it than that. You can take the driveshaft off w/o a needle nose. Replacing U-Js requires much more than removing the snap-rings.
Scotty's 52 F3
Oct 25, 2015 01:20 AM
joe blow
Aug 29, 2014 11:25 AM
mich800
6.4L Power Stroke Diesel
15
Aug 22, 2014 07:45 AM
hairyboxnoogle
Jul 1, 2014 07:01 PM
JerichoM1070
Dec 10, 2003 10:38 PM
