Sponsored by: Auxito
Tire size chart?
Old Aug 31, 2006 | 07:29 PM
  #181
zman764's Avatar
zman764
It does not appear to me that your truck has a lift on it.
As far as fords rims sucking? That mustang is designed to do 2 things. Drive down public streets and sell as many of them as possible. If you are concerned about racing a stock mustang. Your last concern is going to be an extra 150 pounds of wheels. If that.
Old Sep 7, 2006 | 03:56 PM
  #182
hunter17's Avatar
hunter17
Does anyone know what are the largest tires i can put on my 97' F250 without a lift?, stock tires are 235/85/16s
Old Sep 26, 2007 | 08:28 PM
  #183
Speakers's Avatar
Speakers
Having just put a set of 295 - 45/18's on four original 2001 Lightning rims I get no rubbing on my '97 Reg-cab Flareside when turning sharp. As well, I was expecting to have to lower my 4x2's original rather high stance due to the taller rims, but I kinda like the look. On both accounts I was pleasantly surprised. Watch for pics coming soon.
BTW, In November, '00 they switched from a 12mm stud to a 14mm. Just a heads-up!
Old Sep 26, 2007 | 08:42 PM
  #184
Speakers's Avatar
Speakers
Having just put 295 - 45/18's on a set of 2001 Lightning rims I'm experiencing no rubbing on tight corners. And I thought I might have to lower my 4x2's original rather high stance due to the taller rims, but I kinda like the look. On both accounts I was pleasantly surprised.
BTW, in November '00 they changed the 12mm stud to a 14mm. Just a head's up!
Old Sep 26, 2007 | 10:53 PM
  #185
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Just to add:
34x10.50x16 tires will fit on my bone stock '97 F150 4x4 with NO rubbing. The torsion bars have never been touched either...still plenty of threads showing. I have been running 285/75/16 (33x11.50x16) for over a year now with no rubbing. It's been through a lot of fourwheeling as well...
Old Sep 27, 2007 | 06:06 PM
  #186
ididntdoit99's Avatar
ididntdoit99
i didn't get the chance to read eveyones post in here (i'm at work) but the first couple i saw are saying the 285/75/16 are the biggest for a non lifted truck, i have 305/70/16's on my truck with no rubbing at all, same height, but a little wider. i think thats the biggest you can probably go.
Old Sep 28, 2007 | 07:01 AM
  #187
GammaDriver's Avatar
GammaDriver
Stock Ford rims?
Old Sep 28, 2007 | 07:34 PM
  #188
ididntdoit99
yep... pic of them on my cardomain site
http://www.cardomain.com/ride/2296432
Old Oct 19, 2007 | 12:33 AM
  #189
<xF150x>'s Avatar
<xF150x>
SUPER01CREW do you have any pics of your truck , I have an o2 s/c an wonder what it would look like with a little bit bigger of a bite on the rim
Old Nov 17, 2007 | 04:54 PM
  #190
bigastrout's Avatar
bigastrout
I just put 33x12.5 R17 tires on my 2002 F150 Supercrew with a 2 inch torsion key lift. (No Rubbing)
frdf250
Jul 24, 2017 10:40 PM
1jeffm
Jan 19, 2016 07:41 PM
mattsautobody442
2004 - 2008 F150
Aug 12, 2011 06:25 PM
Milwaukee1979F150
Dec 20, 2009 11:16 PM
woodstockaz
Aug 12, 2009 12:42 AM
