Sponsored by: Auxito
Tire size chart?
Old Jun 17, 2004 | 12:11 PM
  #46
bigmack's Avatar
bigmack
I am happy to finally find this site. I have been nosing around for the better part of 10 years looking for a Ford site. My family is a Ford family and I have been driving fords since 71 when I got my first Galaxy 500 convertible.
It is not a typo... I have been riding on 295.75.16's. The 98 lariat came with 17.8 rims and I ditched them for 16.10 bahas. I love these tires. And yes I do run 65psi in them. Seems to help out with wear, and they wear evenly. I rotate about every 8k... Hope this helps. I will try and find a pix of my truck. I am enamored with Ford.
Old Jun 18, 2004 | 08:25 AM
  #47
lariatrider's Avatar
lariatrider
Nope not a typo, I was thinking the same thing. So i checked my database and lo and behold BFG makes a 295/75/16! I own an alignment/tire shop its been a loooonnnngggg time since i've seen that number pop up so I thought they had quit making that size. Nitto also makes the Nitto terra grappler in that size, just to give you some options. I have heard a lot of good things about the Terra Grappler's as well as the BFG's. In the end its all your choice!
lariatrider rides on.....
Old Jun 21, 2004 | 01:02 PM
  #48
fitpays's Avatar
fitpays
cool site for tire size conversion and dimensions. follow this link -find your wheel size and click "show". awesome site. good luck guys. my problem is finding a 17" tire thatis not a million bucks. ford must have a deal with BFG and Goodyear. damn these things are expensive. you'd be better off going to desertrat.com. you can get a whole set of rims and tires for less than what it would cost for just a set of bfg's! look at the packages on 15"rims. then you can easily switch back to your "street tires" when you need to take a long trip or for summer.
Old Jun 21, 2004 | 01:06 PM
  #49
fitpays's Avatar
fitpays
sorry guys -here is the link to the tire conversion charts: http://ejelta.com/tiresize/index.html
try this too:
http://desertrat.com/
Old Jun 21, 2004 | 01:34 PM
  #50
TAMU05's Avatar
TAMU05
yeah the tires are expensive for that size rim, but the bad part is that 15 in. wheels won't fit on 97 and up f150's, i have 16 in. wheels and the tires were not that expensive. hope they will last a while
Old Jun 21, 2004 | 01:43 PM
  #51
bigmack's Avatar
bigmack
I just got a set of BFG AT KO's from Sears for 700.00 and that was 295.75.16's OTD price...
Old Jun 21, 2004 | 02:30 PM
  #52
fitpays's Avatar
fitpays
it is my buddy with the f150. my truck has 16's and i just bought dunlop mud rovers. anyone with 16's should look at these. i got a killer deal on them. 285/75/16's for 125 each mounted and balanced. it seems that 15's and 16's are easy to find a wide variety of, but 17's are tough. just GY and BFG. the dunlops are inexpensive, aggressive looking, and every review i have read raves about them. best of all, people say they have 40,00 plus miles on them and plenty of tread left. i dont know what i will recomend for this friend of mine. i am thinking about asking him if he wants to go with a 265/70/17 mud rover. it is shorter but only by .55 inches. what do you guys think?
Old Jun 21, 2004 | 02:36 PM
  #53
fitpays's Avatar
fitpays
he just pulled up -turns out his ARE 265 70 17 -problem solved! mud rovers it is.
Old Jul 1, 2004 | 08:13 AM
  #54
TAMU05's Avatar
TAMU05
you should be able to run them without the leveling kit. you can run 31's with the leveling kit.
Old Jul 1, 2004 | 01:34 PM
  #55
bdavy's Avatar
bdavy
Largest tire on stock 02 4x4
I am running a 325 60 x18 Toyo AT's all around on my 02 4x4 with no lift and only minor rub on the back side of the front tires at full turn. I did have to shave the bumper valance a touch with a die grinder to prevent contact there. I have checked on several tire web sites that only offer up to a 285 for this application.
I will have to say that I am impressed with the tire and the improved handling.........I tend to drive my 4x4 like a hot rod and love to stick the nose in hard on corners. Only thing I need to do at this point is reduce the body roll in front and improve braking to really enjoy driving it.
Old Jul 1, 2004 | 07:32 PM
  #56
Montana Bronco's Avatar
Montana Bronco
How did they fit ? Did you need a lift ?
Any photos ?
Old Jul 2, 2004 | 06:53 AM
  #57
bigmack's Avatar
bigmack
Any photos ?
I am workin on the photo's, as for fit they fit fine without a lift, I had to crank up my torsion bars a bit to prevent scrubbing when I made hard turns but that has not effected anything so far, I have had the wheels realigned and there seems to be no ill effect whatsoever, and they look real good, IMHO
Old Jul 13, 2004 | 09:31 AM
  #58
Smith6301's Avatar
Smith6301
I have a 2001 F150 4x4 s/c with 285 75R 16 with stock suspension and they fit and look nice, no probs at all, i really like them, by the way they are BFG all terrian t/a's
Old Jul 16, 2004 | 10:23 PM
  #59
Montana Bronco
How about 255/85/16 on a 2003 4x4 reg. cab ? (on stock 16x7 wheels)
This would be a 33" x 10". Tall and narrow.
BFG makes one in an MT, but not AT. $152 at Costco.
I live in Montana and this would be good for up here if it fits.
I would get the center lugs siped, of course...
Forget the above.
I just bought AT's in 285/75/16, mounted on the stock rims.
They look good and ride good.
I'm happy.
Old Aug 13, 2004 | 11:28 AM
  #60
Mikes974x4's Avatar
Mikes974x4
I have a 97 4x4 and my nephew and I put 305 x 50 x 20's on. They look really good and fill the wheel well better. There are no clearence problems. I've been wondering about speedo recal. The truck will only be used for trips to Lowes and such.
Thanks
