Tire size chart?
Anyone interested in doing a bunch of research and making a chart of what fits what? I guess both 4x2 and 4x4. How big of tires will fit with different lift kits etc would be helpful too.
If anyone or a couple people want to work on that we could add it to the FAQs at the top of the forum.
I'd rather not just have a link to another site with the info. If we had our own chart it would be better.
It doesn't pay anything other than recognition and knowing that you've helped
That's the same as us moderators get paid
Super
97-03 F150 4x4 / 97-01 Expedition 4x4
Lug Size: 12x1.75mm or 14x2mm (depending on year)
Bolt Pattern: 5x135mm
Lift: None
Tire Size: 285/75R16
Wheel size : 16x8 (1)
Lift: 3''
Tire size: 305/70r16 or 17", or 33x12.50
Wheel size 16x8 (1), 17x8 (1), or 16.5x8.25
Lift: 4" *
Tire size: 35x12.50R16.5 or 315/75R16
Wheel size: 16x8 or 16.5x8.25
Lift: 5-6"
Wheel size: 16x10 (2) or 16.5x9.25
Lift: 8-9"
Tire size: 36x14.50
Lift: 10-12"
Tire size: 38-39"
Wheel size: 10-12"
The F150 / Expeditions are prone to vibration problems when using wide wheels or tires.
For daily drivers, use 8" wide wheels and 12.50 width tires maximum.
(1) Wheel must have OEM backspacing.
(2) Bumper may need minor trimming, recommend using 8" or 8.25" wide wheels due to clearance & vibration problems.
*Minor trimming may be required.
Just my .02
I know that there are people that are running larger in some of the cases that i've posted.
But, you need to remember that there are many variables, for example a 3" lift in brand A is generally not the same as a 3" lift in brand B.
Also, true tire sizes across brand names are also different, and also the difference in height between new and used tires.
And there's also the kind of shape your front end is in too, a newer less abused front end will often fit a bigger tire than a front end that has been abused.
Racer, I'm not sure how many stickies you want up top, but this would be a great sticky, IMHO. Good info, 'cept that some stockers with no lift have 17" rims and I'd like to know what the biggest tire is for that app. KILLER LIST! Thanks, super!
For example non lifted 285/75r16 is max for a truck with 16's
Specs for a BFG AT's in the above size (pulled these of BFG's site)
32.9'' tall, reccomended rim size 7.5-9.0'', and has a section width of 11.3'' on a 8'' rim.
Now compare these numbers to a 17'' tire.
Just happens a 285/70R17 comes close...
32.8'' tall, reccomended rim size 7.5-9'', and sect width of 11.5" on a 8'' rim.
By saying a 285/75r16 is the largest non-lifted tire, I'm really saying a tire of 32.9'' tall, reccomended rim size 7.5-9.0'', and has a section width of 11.3'' on a 8'' rim is the size needed. (keep in mind that these are "nominal sizes")
The 285/70r17 will be just a hair bit wider, but very barely noticeable, and stood against a 285/75R16, only difference will be the bead size.
Hello,
Can I put a 33 inch tall tire onto a stock XLT Supercrew 4x4?
I don't know what the list is but, it is a lot higher than a 4x2.
So much so that the stock wheels and tires look puny.
Peter...
If you have 17'' rims, as I do, you could go with the 285/70r17's, they come in at 32.8'' on average.
No lift = up to 29 in. tall (265-65-16)
3.5 in. lift = up to 33 in. tall (285-75-16)
4-5 in. lift = up to 33.5 in tall (295-75-16)
6 in. lift = up to 34 in. tall (305-75-16)
7 in lift = up to 35 in. tall (315-75-16)
any questions about tire and wheel sizes go here:
http://www.procomptires.com/tireconversionchart.htm
Thanks Tamu,
Do you know what the lift is on a stock 2001 XLT Supercrew 4x4?
From what I can tell, with stock tires (255-75-16) there is at least 8 in. of clearance between the tire and the edge of the fender. Even a 33 in. tire would still leave at least 4 in.
Is that enough space for a 33 in? What do you think.
A 285/75R16 (approx 32.9'' tall) will be the max size for any 4x4 F150 frame, with out a lift.
I know with my truck '00 F-150 4x2 if I try to put bigger tires on, my tow capacity goes way down and I lose lots of power not to speak of the wheel travel that is lost due to the larger tire.
One common way to compensate for pwr loss is to regear your rearend, and this can be realtively cheap to do on a 2wd truck.
They are cupped on the inside...and worn in the middle.
My tires are Vanderbilt Radial RVT Wild Spirits. They have around 30000 miles on them and they were on 16X7 rims for the majority of those miles. That is why they have worn on the middle so much. The whole truck vibrates bad at about 35 and at about 70. It is really weird though, because it is worse in the early morning.
It also is significantly worse right after a rotation, which leads me to believe that new tires would solve the problem.
P.S. I did a formula involving my GVRW and my max pressure to put in the tires to figure out how many PSI to run. The max is 65, I run 60
Chances are that the cupping is indiaction of needing an align ment. Running your torsion bars cranked up for 300 miles may hve been enough to change the torsions bars, that when you let them back down, they were out of whack and caused the tires to cup....or it just may be the steering alignment...in either case I reccomend an alignment.
30K miles is really nothing to sneeze at for an AT tire (im assuming it is an AT), and considering the high psi's that your running, I have seen alot worse in wear miles.
Here's my reccomendation, If going with new tires, get your alignment cheked right after new rubber, and run your psi's alot closer to the numbers that are on your door. For example on my 6ply's I run 35 front and rear. You'll see a lot longer tread life, more steering control (you'll be using the whole tire instead of just the center), and over all better ride. If you need to tow something, then just bump up the rear tires to the max psi on the tire, then let them back down after your done towing. 35 front and 40 rear, are more than enough psi's for an F-150.
BTW, when and if you get new rubber, make sure to have the tire guys run the rims on a balancer with out a tire, to see if your rims are out of whack.
Hope i wasnt too long winded.
Hope I made some sense.
