Sponsored by: Real Truck
G2 Powerstroke 6.0L
Old Sep 29, 2001 | 12:33 AM
weldman's Avatar
weldman
G2 Powerstroke 6.0L
Don't know if anyone has posted this or not yet, but Truck Trend this month has quoted the power numbers for the new 6.0L Powerstroke.
6.0L
305hp @ 3600rpm
550lb-ft @ 2000rpm
7.3L
275hp @ 2600rpm
525lb-ft @ 1800rpm
Anyone know when the 6.0L will become available?
Matt
https://www.ford-trucks.com/dcforum/User_files/3ae0a7e34062b4ad.jpg https://www.ford-trucks.com/dcforum/User_files/weldman/3b8be147257a8888.jpg
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old Sep 29, 2001 | 05:37 AM
blackbeauty's Avatar
blackbeauty
G2 Powerstroke 6.0L
Everything I've heard points to the 2003 model.
Old Nov 19, 2002 | 06:34 PM
LRECCTX73's Avatar
LRECCTX73
G2 Powerstroke 6.0L
The new powerstoke is supposed to be put out on time. Most dealerships should be getting them by the end of November to the first of December. But let me tell you, this thing is phenominal!! I got to drag race in one of these pulling 6000 pound, spinning tires and all, you will be hard pressed to find another diesel that can do that. Not only that but its probably the quietest diesel that you have ever heard and they redesigned the transmission to take the power of this engine. It is an all around bad *** truck. Take it from someone who has driven it....me!
LRE
Old Nov 20, 2002 | 06:46 AM
nafzimo's Avatar
nafzimo
G2 Powerstroke 6.0L
> ...Take it from someone who has driven it....me!
>LRE
I'll bite. How'd you get to drive one LRE? More importantly... can I drive? :-)
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Nov 20, 2002 | 07:19 AM
johnsdiesel's Avatar
johnsdiesel
G2 Powerstroke 6.0L
Thoses specs are wrong. They are 325 HP @ 3300 RPM and 560 lb ft/torque at 2000 RPM. Check it out for yourself at Ford's website.
Old Nov 20, 2002 | 07:48 AM
FTE Ken's Avatar
FTE Ken
G2 Powerstroke 6.0L
You've got to stop reading those magazines! :-) They are months behind in reporting! We published the story in May with the correct (at that time) numbers:
https://www.ford-trucks.com/news/newsg3.html
325HP, 550 ft/lbs (at 2000 rpm).
The latest numbers, from November 5th:
325 horsepower and 560 ft/lbs.
Old Nov 20, 2002 | 08:15 AM
Coolbreeze's Avatar
Coolbreeze
G2 Powerstroke 6.0L
A question for Ken on this topic. I own a 02' F-350 PSD,CC,LB,SRW. Will the new auto trans behind the 6.0L fit into my 02' F-350 behind the 7.3L with out any or minimal modifications.
Thank you for your time,
Old Dec 1, 2002 | 09:40 AM
weldman's Avatar
weldman
G2 Powerstroke 6.0L
Look at the date I posted this : September 29, 2001.....best we knew at the time.......
Old Dec 1, 2002 | 12:28 PM
ke6jcf's Avatar
ke6jcf
G2 Powerstroke 6.0L
Old Dec 1, 2002 | 12:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
G2 Powerstroke 6.0L
>modifications.
I'm not Ken, but I know the answer to this question.
No, it will not fit in your truck.
The rear face of block/bellhousing pattern is different. The wiring is different.
Those are the two easy things to fix. I'll bet you could fix both of those for no more than what you paid for your truck! :-staun
The hard part is that the programming that runs the engine and transmission is located in one computer. The computer needs to run a 6.0L Powerstroke along with the TorqShift transmission or it isn't going to operate. If the transmission software doesn't get the proper inputs from the engine software the transmission isn't going to shift.
weldman
Nov 5, 2001 04:26 PM
weldman
Oct 28, 2001 11:20 AM
weldman
Aug 28, 2001 04:20 PM
weldman
18
Aug 12, 2001 07:55 PM
weldman
Apr 30, 2001 07:12 PM
