NP435 Close or Wide Ratio?
Old Apr 29, 2001 | 04:04 PM
weldman's Avatar
weldman
I have what I believe to be a NP 435, but is it a close or wide ratio?
I do have the low firat gear, that you have to stop to engage.
Thanks!
D8TA 7108 FB FE 6
2 10 78 2 435
https://www.ford-trucks.com/dcforum/User_files/3ae0a7e34062b4ad.jpg https://www.ford-trucks.com/dcforum/User_files/3ae0a7b33fe32dbb.jpg
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old Apr 29, 2001 | 04:25 PM
sleddingbetty's Avatar
sleddingbetty
NP435 has an aluminum top cover, and a "push and twist" style shift stick retainer. A borg warner is all cast iron, and uses a "screw down" shift stick retainer. I don't believe there are ratio choices on the 435, but could be mistaken.
THE SURGEON GENERAL NEVER SAID A THING ABOUT SMOKIN' A CHEVY!!
Old Apr 29, 2001 | 04:30 PM
weldman's Avatar
weldman
[font size="1" color="#FF0000"]LAST EDITED ON 29-Apr-01 AT 05:33 PM (EST)[/font][p]Maybe not in ford trucks, but was just wondering. References close and wide ratio! See Fourwheeler magazine, june 2001, page 66.
Old Apr 29, 2001 | 11:54 PM
FE427TP's Avatar
FE427TP
I believe Ford got the wide ratio and GM and mopar got the close ratio, but that is merely a relative term as compared to say the toploader
Old Apr 30, 2001 | 03:27 PM
dinosaurfan's Avatar
dinosaurfan
If memory serves me correctly, the NP435 ratios are the same if they came behind the gasoline engines. Some diesels came with close ratio, 4.09 1st instead of 6.68. DF
Old Apr 30, 2001 | 03:56 PM
6t6merc's Avatar
6t6merc
I believe the close ratio version is known as a 445. I had one in a Fargo and recall that the ratios were better suited for just drivin' around than those in the 435 I have now in my Merc. I suppose you could make a Ford 445 if you had one of each.
Eric D
Old Apr 30, 2001 | 07:12 PM
jowilker's Avatar
jowilker
weldman
Jul 11, 2001 11:53 PM
weldman
17
Jul 5, 2001 10:52 PM
weldman
Jun 24, 2001 06:34 AM
weldman
Jun 21, 2001 11:07 PM
weldman
18
Jun 6, 2001 07:16 AM
