Disconnecting inline block heater.
Old Aug 3, 2001 | 08:52 AM
weldman's Avatar
weldman
How do I go about disconnecting this heater (its hooked into the heater core supply line) (much like a tractor block heater) Its actually the same heater as on our John Deere tractors (looks cylinder shaped)
Would the return line to the engine be to a freeze hole? Would a freeze hole plug plug up my problem?
How do I ensure that there are no air pockets in the cooling system after letting coolant leak out?
Thanks!
Matt
https://www.ford-trucks.com/dcforum/User_files/3ae0a7e34062b4ad.jpg https://www.ford-trucks.com/dcforum/User_files/3ae0a7b33fe32dbb.jpg
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old Aug 3, 2001 | 10:43 PM
otto's Avatar
otto
[font size="1" color="#FF0000"]LAST EDITED ON 03-Aug-01 AT 11:45 PM (EST)[/font][p]just disconnect the heater hose off the water pump and heater core and replace that hose or you could half acidly splice it together, or do you have one of those gay "y" shaped things in there ?
also no freeze plug can be tapped as in threaed to accept a npt thread
Old Aug 4, 2001 | 12:27 PM
weldman's Avatar
weldman
I have one of those gay y things in there!
How do I plug the hole in the block in the best way??
Thanks!
Matt
Old Aug 4, 2001 | 07:37 PM
otto's Avatar
otto
I think its a 1/2 pipe thread so use one of those pipe plugs with a sqaure head
Old Aug 4, 2001 | 10:57 PM
jowilker's Avatar
jowilker
If you like in the sunny south and don't require the heater, like me, just run the hose from the pump to the HC and from the HC to the intake.
Piece of cake. You may want to install a cutoff valve so you can stop the hot water flow in the summer.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Aug 5, 2001 | 02:44 AM
1911bronco's Avatar
1911bronco
Sorry...if you disconnect this feature...WE will not let you enter North Dakota....lol
Old Aug 5, 2001 | 07:55 AM
jowilker's Avatar
jowilker
Greg, would that make your truck like possum road kill?
John
jowilker
66F100s Rule
Old Aug 6, 2001 | 08:08 AM
weldman's Avatar
weldman
The heater has never been needed in the last 23 years, even in cold Canadian winters, as the truck is always garage kept.
If a heater is ever required, I will just install a normal block heater that is much nicer on the eyes!
Thanks guys!
So a pipe plug eh? OK!
Do I need to look out for air pockets in the cooling system while disconnecting any coolant lines or is this not a problem as long as I don't ewmpty the rad too much??
Matt
Old Aug 6, 2001 | 11:52 AM
1911bronco's Avatar
1911bronco
John
Why yes John...I believe it would.
Old Aug 6, 2001 | 12:38 PM
jowilker's Avatar
jowilker
Matt, If you don't have any use for the heater at all, just make a short loop from the pump to the intake so the circut is complete and forget everything else. No need to worry about air.
John
jowilker
66F100s Rule
Old Aug 6, 2001 | 10:03 PM
weldman's Avatar
weldman
Sorry for the confusion, I need the heater, just not the block heater!!
Once again, do I need to worry about air pockets in the cooling system when disconnecting lines and losing fluid?
Thanks!
Old Aug 7, 2001 | 06:20 AM
jowilker's Avatar
jowilker
Again, No need to worry about air.
John
jowilker
66F100s Rule
Old Aug 7, 2001 | 06:41 PM
weldman's Avatar
weldman
Thanks guys!!!!!
Old Aug 8, 2001 | 01:06 AM
jeff70's Avatar
jeff70
You shouldnt have to worry about air in the cooling system but to be sure when you finish the job and add coolant just leave the radiator cap off and start the truck, then wait untill the thermostat opens, if you have any air it will bubble out then.
Old Aug 11, 2001 | 09:05 AM
dinosaurfan's Avatar
dinosaurfan
Weld, what is a 'normal' block heater ? I would like some kind of heater for my truck but the place we go for vacations has no electricity (western U.P. Michigan) Might you be thinking about a thermotop? DF
