Tremec trans
Old Mar 17, 2026 | 11:47 AM
pdhulteng's Avatar
pdhulteng
Tremec trans
So on the 94 F150 2wd the stock 5 speed crapped 3rd and 4th gears. I am going to hop the 302 up with aluminum heads and a healthy cam so I was thinking about changing the tranny out to maybe a Tremec 5spd and need any thoughts or anyone who has done it.
Thanks, Paul.
Old Mar 17, 2026 | 11:51 AM
90project5.0's Avatar
90project5.0
Changing the axle ratio as well? I would go 3.73 or 4.10s to help it get off the line better.
Old Mar 17, 2026 | 12:18 PM
torq'ta 5 8's Avatar
torq'ta 5 8
What hp are you hoping to get out of it, anything over 290-300hp you'll need to tune it, and that isnt cheap on OBDI, unless you know how to, or you have a buddy...that can be bought with spirits.
Old Mar 17, 2026 | 03:40 PM
pdhulteng's Avatar
pdhulteng
I will change the gears. Probably to 410s.
Old Mar 17, 2026 | 03:41 PM
pdhulteng's Avatar
pdhulteng
Hoping around 400.
Old Mar 17, 2026 | 04:19 PM
90project5.0
They are great until the highway at 85!
Old Mar 17, 2026 | 06:54 PM
pdhulteng's Avatar
pdhulteng
Maybe 3.73. I believe it is 3.55 now.
Old Mar 17, 2026 | 07:41 PM
90project5.0
If I redo my axle again, that’s what I’ll go to. 4.10s have been great with stop and go traffic pulling a trailer, but that 4.5 drive to see my kid sucks! 75 mph is around 3100rpm. I’ve contemplated having a set of oversized tires for the rear just for longer trips.
Old Mar 18, 2026 | 08:30 AM
Hit Man X's Avatar
Hit Man X
Torque breaks parts and shock loads. A 400hp 302 is not going to make much torque with that little 3" stroke
Old Mar 18, 2026 | 02:34 PM
My4Fordtrucks's Avatar
My4Fordtrucks
or work with the stock speed density EFI computer.
Old Mar 18, 2026 | 03:44 PM
Hit Man X's Avatar
Hit Man X
I am with you on that, yet a 400hp 302 will probably have a torque peak around 4500, give or take 500rpm. If after that, badass, keep us informed on the build.
It will act like a cammed Gen 3 GM. Been around those since late 90s.
Old Mar 18, 2026 | 04:11 PM
90project5.0
Too much further past that and the block gets real iffy real quick.
Old Mar 18, 2026 | 06:21 PM
pdhulteng's Avatar
pdhulteng
I am also putting together a 408 aluminum headed roller stroker that may end up in it.
Old Mar 18, 2026 | 06:48 PM
90project5.0
That’ll do pig, that’ll do!
Old Mar 19, 2026 | 10:20 AM
pdhulteng's Avatar
pdhulteng
My dad bought the truck new so it will be passed on to one of his great grandchildren.
dzimbric
Jul 17, 2024 03:47 PM
mjf
Dec 21, 2008 10:17 PM
Ford Truck Racer
Sep 6, 2004 10:21 PM
fast_eddy
1978 - 1996 Big Bronco
Nov 28, 2002 02:59 AM
