No power at Brake Controller Harness
Old Feb 18, 2026 | 07:43 PM
F150inTN's Avatar
F150inTN
5th Gear
Hi everyone, new guy here. I need some assistance with adding a brake controller to my 2008 F-150 xl regular cab 2wd.
I bought premade wiring harness to connect a controller, but after getting it all plugged in I am getting no power to the controller.
I’ve checked the kick panel fuse in position 105 and swapped in a relay to R05. Still nothing. Is there anywhere else I need to check or add a fuse or relay?
Thanks in advance.
Old Feb 19, 2026 | 05:05 AM
techrep's Avatar
techrep
check the fuse 101 that supplies tow power.
Old Feb 19, 2026 | 11:12 AM
F150inTN's Avatar
F150inTN
5th Gear
Thanks for the response techrep. On my panel fuse 101 appears to be for the starter solenoid.
Old Feb 19, 2026 | 07:54 PM
Don Ridley's Avatar
Don Ridley
*****Edit*****this information is wrong . I was looking at a 2001 truck****
Fuse 108 is trailer tow electric brake 30 amp maxi fuse. This is the fuse box in the engine compartment.
Old Feb 19, 2026 | 08:15 PM
F150inTN's Avatar
F150inTN
5th Gear
Thanks. Ok so dumb question…where is the underhood fusebox? The only thing I’ve been able to find is a small rectangular box mounted on the driver side fender with a couple of fuses in it.
Old Feb 19, 2026 | 08:29 PM
Don Ridley's Avatar
Don Ridley
Driver side under the hood.
https://www.google.com/url?sa=i&sour...71640782017000
Old Feb 19, 2026 | 08:47 PM
F150inTN's Avatar
F150inTN
5th Gear
This truck is a 2008, so it’s the generation after the one in the video.
Old Feb 19, 2026 | 09:32 PM
Don Ridley's Avatar
Don Ridley
Oops. Somehow I was looking at 2001. Nevermind 😬
Old Feb 20, 2026 | 04:41 AM
techrep's Avatar
techrep
does 106 have a good fuse ?
Old Feb 20, 2026 | 10:45 AM
Don Ridley's Avatar
Don Ridley
Here is the 2008 trailer brake module diagram. Make sure your pre-fab harness matches.
The dark blue (DB) wire is the trailer brake signal.
Old Feb 20, 2026 | 11:24 AM
F150inTN's Avatar
F150inTN
5th Gear
Don, you’re right on track, and just came to post an update.
Last night I started the process of eliminating the less likely causes. I unplugged the prefab harness and started comparing the wire locations in it versus the truck plug.
Well, the red and black wires were put into the prefab connector on the wrong side of the plug bank!
I disassembled the plug, moved the wires over to the correct side, and now the controller has power and is working.
Thank you to everyone that assisted helping to narrow down this problem!
Old Feb 20, 2026 | 11:41 AM
Don Ridley's Avatar
Don Ridley
Nice! Good job.
JackRanch
All Things Towing
Feb 14, 2018 09:58 PM
JackRanch
Feb 11, 2018 06:21 PM
woodtrucker
Jul 19, 2013 11:42 AM
skimore2020
2004 - 2008 F150
Nov 2, 2010 02:02 PM
redbug
Jul 1, 2010 08:06 PM
