1994 F-250 C&C brake controller question - Ford Truck Enthusiasts Forums
Old 02-12-2018, 05:49 PM
JackRanch
JackRanch is offline
JackRanch is starting off with a positive reputation.
Hi everyone. I am not getting power to my brake controller. I bought a new pigtail and controller itself and installed. Still no power. The #21 fuse space is empty but it will not hold a maxi fuse like it calls for. It just flops around in the spot for the fuse. Any ideas? Thanks in advance!
Old 02-13-2018, 02:14 AM
mrollings53's Avatar
mrollings53
mrollings53 is offline
mrollings53 is gaining momentum as a positive member of FTE.
It's because you don't have the relay box that would have been installed next to the power distribution box in your picture. You will have to wire power to the brake controller directly.
Old 02-13-2018, 06:46 AM
JayTheCPA
JayTheCPA is offline
JayTheCPA is gaining momentum as a positive member of FTE.
At the risk of insulting . . . Might want to consider taking the truck to a trusted trailer shop or independent shop that sees a lot of pickups, tell them where you want the controller mounted, and let them do the install.
Reasoning is that unless you are handy with 12v automotive systems, it will prove less frustrating for somebody who does this regularly.
Old 02-14-2018, 09:58 PM
jetjockey99
jetjockey99 is offline
jetjockey99 is gaining momentum as a positive member of FTE.jetjockey99 is gaining momentum as a positive member of FTE.
Also it looks like there are NO contacts for the fuse in your picture. If that is the case just wiring 12v. direct to the controller is probably the easiest way to do it.
JackRanch
02-11-2018 06:21 PM
deerhunt799
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-03-2017 01:29 PM
johnsonjf
09-13-2017 09:37 PM
Wingit929
1999 to 2016 Super Duty
06-05-2017 04:40 PM
perryg114
10-24-2016 12:28 PM
Quick Reply: 1994 F-250 C&C brake controller question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
