My 17 6.2 yesterday just out of the blue failed to start. 80 degrees, I had just drove two hrs,...One hr each way. shut off and start at ends of the road,
I pulled in the feed mill, ordered my stuff screwed around a bit, about... 30 min stop. went to start the truck and it would not start, it tried, sounded like it wanted to but couldn't get enough gas.. tried everything with gas pedal I could think of. no start! called for a ride. waited 10 min. hit the key it slow started but started up. no lights. idle was perfect?? seemed like it never happened. but now I don't trust it!
It's the fuel pump more then likely. We have two trucks at work that were having hard start issues and it got to the point they would barely start even when cold. Fuel pumps failed the leak down test and were replaced. Trucks fire right up every time now
