Problem?
Old Oct 27, 2010 | 06:12 PM
01kingranchKY's Avatar
01kingranchKY
Problem?
My truck has recently started acting strange. Sometimes it will not start. It acts like it is not getting any fuel. It may take several tries but it eventually will start and runs fine. This may happen 2 oro 3 times a week. Is it the fuel pump or something else? Anybody got any ideas?
Old Oct 27, 2010 | 07:46 PM
fldave's Avatar
fldave
Sometimes if the check valve in the fuel pump goes bad, the fuel line will go empty and will take a little time for the pump to prime. Does this only do this on first start of the day?
Old Oct 27, 2010 | 07:52 PM
MCDavis's Avatar
MCDavis
I've had this happen in my '06 a couple of times. It cranks, fires, then dies almost like it's being choked out. Mine doesn't do it on the first start. It's usually after I've been running for a while, shut down to go into a store, come back 5 minutes later, and it does this.
I'm subscribing to see what others might say
01kingranchKY
No, it could be anytime. First start of the day or 20 min. after I last shut it off.
Old Oct 27, 2010 | 08:26 PM
javieljb's Avatar
javieljb
Has the fuel filter been replaced yet?
How many miles?
What year?
Old Oct 28, 2010 | 07:05 PM
Greg B's Avatar
Greg B
Are there any codes? It could be a fuel pump driver module or fuel pump. It could have a P0191 code and not luminate the MIL. That would indicate the driver module. Had that problem on the wife's 02 Taurus and it had the P0191 code, which is a fuel rail pressure problem. Since the driver module and fuel pump are all in the fuel pump on the Taurus, a new Bosch fuel pump solved the problem.
Old Oct 28, 2010 | 07:55 PM
01kingranchKY
I will check for codes tomorrow.
vaultster
Mar 19, 2007 07:19 PM
hotrod3367
Feb 18, 2005 08:42 AM
T & V
16
Sep 3, 2004 02:56 PM
mrcobra350
Mar 1, 2004 11:13 PM
EvilAerostar
Aerostar
Nov 28, 2001 02:44 AM
