1996 ford f150 4.9 starting problems sometime
I have been having problems with my truck starting. Sometimes it starts right up and runs perfect, sometimes it takes a few tries, and sometimes it won't start at all just tuns over then if you come back a few hours later it will start perfect first try. my fuel gauge also doesn't work so don't. no if that has anything to do with it thinking probably the fuel pump just was wanting some other opinions thanks. The fuel pump does run every time you try starting wether it starts or not.
Here's a possibility for random no start, intermittant no start, etc.
Click this link: A9x ECM's (and same years ECM's) Failures Due to Age
Our PCM's are aging and failing quite frequently now.
This may or may not be your current problem, but in all likelyhood it'll become an issue that you'll have to deal with.
Bob
JJsthing
03-23-2010 09:45 AM
