Steering column replace
Old Oct 24, 2025 | 06:25 AM
jewelzf350's Avatar
jewelzf350
4wd Low
Exclamation Steering column replace
Have a 06 350 SD XLT and she's been doing fine. I stopped to dump some yard debris, go to fire it back up a few minutes later, DEAD. Nothing. Never happened before. After a good hour and a half, she started right up. Another week goes by, bam. Happened again. This time i noticed that i couldnt hear the glow plugs warming up. My shifter has been getting more and more play over the past year. So I held the shifter up thinking that it wasnt engaging into Park all the way, and she started up...
My question is (I'm positive I need a new column, but which do i need? Im pretty sure i need the 5 speed auto with tilt and cruise, but it has 6 speeds really... But for parts sake, its the 5 speed auto, right?
But then Im coming across other XLT models at B&R that have the 4 speed...
Help...
Old Oct 24, 2025 | 06:58 AM
Fuzzpuss's Avatar
Fuzzpuss
You don't need a steering column.
Post #34
https://www.ford-trucks.com/forums/1...with-it-3.html
Old Oct 24, 2025 | 12:10 PM
runthatjunk's Avatar
runthatjunk
There's a couple bolts that work loose, maybe attaches the cable to handle? Have you checked those? On column under the dash
Old Oct 26, 2025 | 10:43 AM
BLADE35's Avatar
BLADE35
Post #34
Nice post great find
Old Oct 27, 2025 | 07:48 PM
jewelzf350's Avatar
jewelzf350
4wd Low
Post #34
It's a great post, but I didn't see anything about a loose shifter not slowing the truck to start...
Old Oct 27, 2025 | 07:51 PM
jewelzf350's Avatar
jewelzf350
4wd Low
I sorta forgot I make a post about it... Sorry for late reply...
I'm gonna check it right now...
Do you know of any diagrams or breakdowns of the steering column?
Now the truck WILL NOT start at all. Feels like the shifter is about to fall out...
Old Oct 27, 2025 | 07:53 PM
jewelzf350's Avatar
jewelzf350
4wd Low
Ok. I realized when I clicked the link it took me to post number 82... Like you said post 34... I'm a *******... Thx
Old Oct 28, 2025 | 09:51 PM
Fuzzpuss's Avatar
Fuzzpuss
Thank you. It was easy to find considering I wrote it.
Old Oct 28, 2025 | 09:53 PM
Fuzzpuss's Avatar
Fuzzpuss
This little bugger can also cause problems with the shifter, and by extension, the starter:
Amazon Amazon
It can be had with the shifter tube bushings as a kit for $12 on amazon.
Bluesopher79
Jun 17, 2021 08:21 PM
BSCowboy
Feb 26, 2017 04:36 PM
mando jake
Dec 18, 2009 03:09 PM
IowaTower
Jul 4, 2006 06:41 PM
nigel6950
Apr 25, 2003 12:12 PM
