7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Transmission Temp
Old Jul 3, 2025 | 06:40 PM
bucfan11's Avatar
bucfan11
Transmission Temp
2025 F350 6.8
I just took delivery a couple weeks ago. Been driving a lot to hit the 1000 mike break-in. I noticed while driving around my trans temp would be as high as 211. I pulled a 10000 lb camper 60 miles today and the temp was 218. I did not think much about it until I seen.my brothers 21 Ram diesel. He pulled 13000 lb camper to the exact place I did. His trans temp was 184. Are these high temps normal?
Old Jul 3, 2025 | 08:47 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Ford tends to run their transmission temps a little on the high side so I wouldn't worry about it.
Denny
Old Jul 3, 2025 | 10:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those are normal temperatures. The transmission has a thermostat that keeps the temperature higher than the Ram.
Old Jul 4, 2025 | 01:02 PM
SMSTX's Avatar
SMSTX
Mark what would you recommend for service interval? I've been recommending fluid exchange at 50k and filter around a 100k to my customers but, am considering doing shorter intervals on my personal 10R100 and adding a deep sump aluminum pan.
Old Jul 4, 2025 | 02:22 PM
Mark Kovalsky
I don't know for a 10R100.
Before 2008 the filter was good for the life of the trans. Starting mid year 2008 with the 5R110W the internal filter became a real filter that does need to be changed. I recommend 60K on that filter.
Old Jul 4, 2025 | 03:26 PM
rvpuller's Avatar
rvpuller
On my 2013 6 speed I changed the fluid and filter at 50K and the filter was do to be changed, I changed it again at 100K and it was clean a long with the pan. I don't plan on ever changing the filter again.
Denny
Old Jul 4, 2025 | 05:23 PM
SMSTX's Avatar
SMSTX
On the 6 speeds when customers come in with the torque converter shudder, most have never been serviced so we always recommend starting with the trans filter and fresh fluid before going to the torque converter. The 10r's are a different animal
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
tuf4x4
Jul 23, 2011 05:32 PM
Myckel
Apr 7, 2006 08:00 PM
JRB
Jan 2, 2005 08:54 PM
AV3Fire
Sep 7, 2004 06:24 PM
