Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 F600 decode
Old Jun 30, 2025 | 10:20 PM
Bspradtrucker's Avatar
Bspradtrucker
6th Gear
1966 F600 decode
Sorry if this isn’t the right place to post this I just signed up but I was looking for help decodeing the vin on my 66 f600.
Old Jul 1, 2025 | 07:43 AM
85e150's Avatar
85e150
I'll get back to you later today or tomorrow.
preview:
F600, 330 and NP435 four speed.
Old Jul 1, 2025 | 08:26 PM
85e150's Avatar
85e150
F60 = F600 gas, 4x2
C = 330 2V Medium Duty FT gas V8
K = Kansas City Assembly Plant
804614 = 1966 numerical series, January 1966 production
174 = 174 inch wheelbase
W = Medium Blue
F600 = F600, 17,000 lbs GVWR
M81
M = Beige Woven Plastic and Beige Vinyl with Foam Cushion
81 = Cab and chassis vehicle
A = New Process model 435 four speed transmission
F8 = Eaton model 13802 two speed rear axle, 15,000 lbs capacity, 6.33 / 8.81 ratios
No front axle code. In MY '64 to '69 only optional axles are listed. Thus, standard Ford axle, probably at least 4,500 lbs capacity, no power steering.
17000 = 17,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
65 = Oklahoma City District Sales Office
No special order.
No special order means the truck was bought out of dealer inventory. This one differs from the typical in that it has the two speed rear axle. Dealer F600s tend to be low GVWR with single speed rear axles--at least many of the ones showing up here.
Check your wheels--they could be widowmakers.
https://www.ford-trucks.com/forums/8...l#post19892682
If you are not familiar with the two speed rear axle:
https://www.ford-trucks.com/forums/1...ml#post9565523
Old Aug 9, 2025 | 08:52 PM
Bspradtrucker
6th Gear
Originally Posted by 85e150
F60 = F600 gas, 4x2
W = Medium Blue
M81
No special order.
thanks for the help that’s cleared up a lot only thing I haven’t had much luck in finding is a replacement brake booster/master cylinder. Would you have any recommendations?
Old Aug 11, 2025 | 06:23 PM
85e150's Avatar
85e150
Is yours frame mounted, under the driver?
There are several models and makers. If you can find any identifying info on it we could search that out.
Rebuilds and kits are getting hard to find.
Old Aug 11, 2025 | 06:56 PM
Bspradtrucker
6th Gear
Its frame mounted on the driver side I’ll look to see if I see any marking here’s a picture. Probably will need to get a replacement I took it apart and when I put back together the plastic cracked
Old Aug 11, 2025 | 08:01 PM
85e150's Avatar
85e150
I found this from a 2024 post at Binder Planet. Guy said he got one rebuilt in about 2018. YMMV
https://www.brakesystemsinc.com/remanufacturing/
This looks to be current and references truck units:
https://harmonclassicbrakes.com/boosters-and-parts-old/
Some background and what might still be good links to other sources in the final couple posts:
https://www.ford-trucks.com/forums/9...ovac-unit.html
Old Oct 22, 2025 | 08:17 PM
Bspradtrucker
6th Gear
Thanks all for your help I’ve made some progress on it for the brake lines cleaned out changed out the carburetor and water pump. I noticed that I have it on jack stands that in neutral it still tires the driveshaft until I push the clutch.
Is that normal?
Old Oct 22, 2025 | 08:26 PM
85e150's Avatar
85e150
Yes. In neutral with the clutch out, the input shaft turns when the engine is on. Internal friction and oil movement will make the guts of the transmission turn even though they are not mechanically linked. Sometimes they will turn even with the clutch in due again to friiction from the pilot bearing and the very small clearance between the clutch disc and pressure plate--it doesn't take much on a high mile rig for something to be just a little out of square or some material to be hanging out where it shouldn't be to cause a little friction.
Old Oct 22, 2025 | 08:33 PM
Bspradtrucker
6th Gear
ok thanks. What oil would you recommend for the transmission and rear diff?
Old Oct 22, 2025 | 09:11 PM
85e150's Avatar
85e150
Rather than type it all again, follow the links in this post regarding trans, axle and two speed shifter service and oils:
https://www.ford-trucks.com/forums/1...l#post21639226
Old Oct 22, 2025 | 09:47 PM
Bspradtrucker
6th Gear
thanks
Old Oct 22, 2025 | 10:48 PM
asavage's Avatar
asavage
FTE Community Team
I had started to post this link earlier, then realized that both the OP's trans and diff. are different than the one's I'd researched, and thought better of sticking my neck out. The Clarks definitely use those specs, and the Eaton 16xxx diffs, but IDK about the Eaton 13xxx or the NP435, and I decline to go down that particular rabbit hole for a '66, as I don't own the docs for that year.
It's a reasonable guess that Ford standardized their heavy lube specs across the various gearboxes and diffs, but until someone does the research for that year, that's all it is.
Doublet1951
Large Truck
Jul 10, 2025 09:02 PM
JRichardson
Large Truck
Nov 25, 2023 04:36 PM
BadRadDad
Large Truck
Mar 7, 2023 10:57 PM
cousinscustoms
Large Truck
Jul 1, 2021 11:28 PM
vintageant
Large Truck
Apr 20, 2021 05:26 PM
