Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decode Information Please
Old Jun 9, 2025 | 07:59 PM
Doublet1951's Avatar
Doublet1951
5th Gear
Not having a lot of luck decoding the information on the plate. Any help Appreciated. F60AK700419 Need engine size and transmission, rear-end information as complete as possible
Old Jun 9, 2025 | 10:50 PM
85e150's Avatar
85e150
I'll be back to you later today or tomorrow.
Old Jun 10, 2025 | 12:32 AM
85e150's Avatar
85e150
F60 = F600 gas, 4x2
A = 330 2V MD FT gas V8
K = Kansas City Assembly Plant
700419 = 1965 numerical series, June 1965 production
174 = 174 inch wheelbase
G = Chrome Yellow (looks like some peeking out around the warranty plate)
F602 = F600 gas, 4x2, 20,000 lbs GVWR
481
4 = Beige Vinyl
81 = Cab and chassis vehicle
N = New Process model 435 four speed transmission OR Dana (Spicer) model 5652 five speed direct transmission (both use the same code for '64-'65) (Shop manual says 5 speed)
F8 = Eaton model 13802 two speed rear axle, 15,000 lbs capacity, 6.33 / 8.81 ratios
No front axle code. Only optional front axle codes were listed between '64 & '69, so assume this to be a Ford axle with at least 5,000 lbs capacity and no power steering.
20000 = 20,000 lbs GVWR
160 3800 = 160 Certified Net HP @ 3800 RPM
650493
65 = Oklahoma City District Sales Office
0493 = Special Order Number
Check your wheels--widowmaker Firestones were on a lot of these.
Old Jun 11, 2025 | 01:33 PM
Doublet1951
5th Gear
Front hub picture
Wheels look like lock ring but hard to tell
[img alt="Does this mean anything numbers on brake front drum
"]https://cimg3.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1124/20250610_132343_95f9c854f3435cf5ee12ee00b458efedf4 8364f6.jpg[/img]
Old Jun 11, 2025 | 06:32 PM
85e150's Avatar
85e150
Your attachments didn't work. Please try posting them again.
If you can see a split in the ring, you're good.
Old Jun 11, 2025 | 07:11 PM
Doublet1951
5th Gear
Will try to get a better picture. Looking through holes in front wheel I can see the numbers BUDD 87828
budd 87828
budd 87828
Thank You for information. Sorry to be such a pain. Later
Old Jun 12, 2025 | 05:31 PM
85e150's Avatar
85e150
There are no new drums available for your truck. That number doesn't come up when you do a search.
But, if it's in good condition, run it.
Shoes, springs etc are available but a bit of a hunt.
NAPA on line (change your vehicle type to "Medium/Heavy") shows a kit for the rear brakes, and individual parts as well, plus wheel cylinders.
Width and diameter are what you need.
Old Jun 13, 2025 | 12:09 AM
rusty valley's Avatar
rusty valley
Brake and equipment in MPLS MN will reline your old shoes, and most likely have hardware too. No location on your avatar, so I don't know if its close
Old Jul 10, 2025 | 08:27 PM
Doublet1951
5th Gear
I live in Gotebo, Oklahoma.
Changing gear just a little.
If a person wanted to change out complete rear-end assembly ( for something later model ) what would be a good year to start measuring with.
Honestly I can find several trucks in my area that I can buy the complete truck cheaper than buying tires and wheels for this truck.
What years and model numbers (Ford,) rear-end assembly would be compatible?
Old Jul 10, 2025 | 08:47 PM
85e150's Avatar
85e150
I don't know the specs on the spring pads. Are you looking for newer brakes and wheels as the reason for the swap?
Does this truck run? Drive/steer/go/shift/stop?
Old Jul 10, 2025 | 09:02 PM
Doublet1951
5th Gear
Yes mainly runs and drives, brakes need repair.(Wheel Cylinders or kits), Unable to find decent price on replacement tires and wheels for truck. Yes it drives but needs wheel cylinders and brakes on rear. Can find a complete rear-end assemble with ten holes wheels 22.5 and good radial tires.
If I can find one with decent radial tires and wheels it will be cheaper cheaper than replacing all the items and still having to find wheels and tires.
66RedF600
Large Truck
Jun 2, 2025 10:49 PM
wilkes704
Jan 19, 2025 01:54 PM
wilkes704
Jan 19, 2025 08:47 AM
errica
Flathead V8 & Flathead 6
Apr 14, 2021 11:37 PM
crisman
Feb 15, 2018 11:56 AM
