Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 C700 decode
Old Nov 25, 2023 | 01:09 PM
JRichardson's Avatar
JRichardson
2nd Gear
1966 C700 decode
Old Nov 25, 2023 | 04:36 PM
85e150's Avatar
85e150
Welcome to FTE! I'll give you your own thread for the full decode.
A '66 with a 6....
C70 = C700 gas
B = 300 1V six in line gas engine
U = Louisville Assembly Plant
838605 = 1966 numerical series, March 1966 production
175 = 175 inch wheelbase
No color code--note the truck is a special order and color is often the reason
C700 = C700 gas, 24,000 lbs GVWR
691
6 = Black Vinyl
91 = Tilt cab
L = For this model year and weight, 3 transmissions show under this code. You'll have to eyeball it--the case will have numbers etc cast into it, and it may have a tag riveted to it.
--Dana (Spicer) model 6352-B (iron case) five speed direct (showing model year '66 only)
OR
--Clark model 2653 V1 five speed direct
OR
--Clark model 2651-V1 five speed direct
74 = Rockwell model H-140 single speed rear axle, 17,000 lbs capacity, 6.80 ratio
No front axle code: From '64 to '69 only optional axles were identified, so:
--a standard Ford axle of at least 7,000 lbs capacity, unsure about power steering
--an optional axle that is not a reqular production item--this is a special order truck, so the front axle might have been part of that.
24000 = 24,000 lbs GVWR
150 3600 = 150 Certified Net HP @ 3600 RPM
320383
32 = Cleveland District Sales Office
0383 = Special Order Number
Daheffa
Large Truck
Feb 16, 2024 10:27 PM
Sofkee
Large Truck
Jun 11, 2022 02:49 PM
Jamie Miles
Large Truck
Sep 27, 2021 02:50 AM
cousinscustoms
Large Truck
Jul 1, 2021 11:28 PM
vintageant
Large Truck
Apr 20, 2021 05:26 PM
