Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1978 F600
Old Aug 15, 2025 | 09:55 PM
THUNDERJET's Avatar
THUNDERJET
4wd Low
1978 F600
What gear oil is recommended for a Eaton model 16244 two speed rear axle? What type of oil is recommended in a Clark model 285V five speed transmission? What weight of oil is recommended in a 330 2V XD FT engine? How many quarts does each take? Can synthetic gear oil be used? I am wanting to change all the fluids in my 1978 f600 and basically would like to know what everyone uses or what is recommended by the manufacturers. Thanks!
Old Aug 17, 2025 | 12:12 PM
asavage's Avatar
asavage
FTE Community Team
Hypoid GL5 85W-90 (or 85W-140 if your service conditions warrant)
If you want to chase stuff that's never serviced, the 2-speed rear axle shifter (10W oil: substitute 10W30 these days) never gets changed in those, and it gets gummy when the seal between the shifter and the main housing leaks.
https://www.ford-trucks.com/forums/1...mechanism.html
There's only a fill plug, so you have to use a sucker and dip tube, or take the cover off (get a new gasket first).
SAE 50 (or 85W90 GL4, which is getting a bit harder to find). I run AMSOil FTF.
1721081356561.webpasavage · Jul 15, 2024 at 3:11 PM
Do not run a GL5 lubricant in the transmission.
https://www.ford-trucks.com/forums/1...l#post21309839
Quantity? For the Clark 280 Series: 8 pints (4 quarts, 1 gallon) per the 1973 Ford Truck Shop Manual, pg. 16-40-07:
(originally posted here with quantity correction here)
I put 4.5 quarts in mine, but the rig was not perfectly level.
Viscosity requirements vary. If the engine is in reasonable condition, I'd run 10W30, but oil/coolant/spark plugs are kind of like religion, so . . .
Educate yourself on the "flat tappet ZDDP" issue, or just run "for classic cars" oil and ignore it.
I run AMSOil Z-Rod 10W30, but my engine isn't an oil burner and that oil is expensive. I don't run my truck much.
My '73 361 (same basic FT engine as yours) is ~8 quarts in the engine, including the Motorcraft FL-299 or Wix 51773 high-capacity (~1.5 quart) oil filter. Yours is probably similar.
https://www.ford-trucks.com/forums/1...l#post21613767
High-capacity full-flow oil filters like these should be pre-filled prior to installation.
Synthetic lubricants are pretty much all I use. But see "religion" above.
Old Aug 17, 2025 | 09:14 PM
THUNDERJET's Avatar
THUNDERJET
4wd Low
Thank You!
SeaCarr
Jun 3, 2020 01:37 PM
F100 66
Oct 19, 2018 09:36 PM
Pinzer
Large Truck
Dec 20, 2015 10:19 AM
dornauer
Dec 5, 2004 01:08 PM
jowilker
Jan 17, 2001 09:55 PM
