NEEDING NEW/REBUILT BENDIX HYDROVAC UNIT
Old Jul 3, 2010 | 10:03 AM
michaelshewkin's Avatar
michaelshewkin
Question NEEDING NEW/REBUILT BENDIX HYDROVAC UNIT
I am looking for a replacement Bendix Fourth Series - Single Diaphragm Hydrovac Hydraulic unit for my 1962 F600. When these work, they work very well! This truck used to stop on a dime and being used as a Dump Truck with 5 Ton moving down the road, Good Brakes is critical.
The Hydrovac went to leaking internally and when it would sit and then be started it would pull out alot of White Smoke as it burned off the brake fluid through the vacuum circuit.
Had it rebuilt by a rebuild shop, but it still does not have any power assist to speak off and it had been rebuilt before I owned the truck by the same shop.
Would like to find another unit or NEW unit if there would be one on the shelf somewhere?
Any help on this would be appreciated or recommendations on a reputable repair shop who can bench test these as well......
Old Jul 3, 2010 | 04:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/62 F500/600:
There are two different P/B boosters. Since there are two different steering gearboxes, that shouldn't surprise you!
B7T2005A .. P/B Booster-10.00" O/A diameter / Manufacturer: Midand-Ross / Model number: XC-462-H
C1TT2005E .. P/B Booster-12.75" O/A diameter / Manufacturer: Bendix / Model number: 2501001.
Since there are two different boosters, there are two different repair kits.
Finding the repair kit may be possible, the booster less so. All these parts have long been obsolete.
The problem with rebuilding an old booster is...the new parts are old. Ozone in the air, humidity play a major factor in condition of rubber parts.
The new diaphram may be hard as rock and age cracked. How long will it last after being installed?
What will be the condition of a new booster's diaphram, or a diaphram in one of the Ford repair kits?
btw: I did look at the parts catalog pic of the brake system. Some trucks have a cylindrical vacuum tank, with lines running every which way.
If you have this setup, the tank and/or the hoses may be defective, causing loss of brake pressure.
Old Jul 3, 2010 | 08:44 PM
michaelshewkin
Question C1TT2005E .. P/B Booster-12.75" O/A diameter / Manufacturer: Bendix / Model number: 2
Bill,
I have the BENDIX BOOSTER:
Any reputable repair shops who can rebuild these type of boosters?
Old Jul 3, 2010 | 09:12 PM
NumberDummy
Originally Posted by michaelshewkin
Bill, I have the BENDIX BOOSTER:
There was a place in downtown LA, but whether it's still in business or not...I'll have to find out.
I haven't had a Hydro-Vac rebuilt (for a Ford...or Studebaker) since the 1970's.
No Ford Dealer or obsolete parts vendor has the booster.
C1TZ2309A .. P/B Booster Repair Kit-Use w/C1TT2005E / Obsolete
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Coincord NC has ONE = 704-786-8139.
You might contact Jon Myer of Myers Studebaker Parts located in OH (740-674-4897). Jon may have a reliable source since Studebaker used Hydro-Vac's on just about everything thru 1966.
Old Jul 6, 2010 | 08:07 PM
chuckles4's Avatar
chuckles4
Karps Brake Service-Boosters
Old Jul 7, 2010 | 03:07 PM
pbs girl's Avatar
pbs girl
Wink
Power Brake Sales in Sacramento can test and remanufacture yours or they may have one on the shelf.
N600
Large Truck
16
Jul 6, 2024 01:54 PM
lterrip
Large Truck
Mar 20, 2022 11:45 PM
Roger Walling
42
Feb 2, 2019 07:37 PM
desertbus
15
May 27, 2014 11:13 AM
michaelshewkin
Jul 4, 2010 06:48 PM
