Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 F600 Decode
Old Apr 20, 2021 | 01:25 PM
vintageant's Avatar
vintageant
1966 F600 Decode
Looking for help on how to decode this: Thank you!
Old Apr 20, 2021 | 03:17 PM
85e150's Avatar
85e150
Welcome to FTE!
F60 = F600 gas 4x2
C = 330 2V MD FT gas V8 (Uses 352 crank with small diameter nose, FE distributor drive)
C = Ontario Truck Assembly Plant
892257 = 1966 Series Number
156 = 156 inch wheelbase
M = White
F600 = F600 17,000lbs GVWR
481 = I don't have all the info on this code for upholstery, seat type etc. Seems to indicate Standard Cab
A = New Process model 435 four speed transmission. (This code also shows for a 5 speed, but that trans looks like it's for larger trucks, F800+)
F7 = Eaton model 13802 Two Speed Rear Axle / 5.83/8.11 / 15,000 lbs. Rear Axle Capacity
No front axle code. (Info per the MPC and Numberdummy: From '64 to '69 only optional front axles were listed. Starting in '70 all axles are listed. Thus in '64/'69 it's the standard axle, most likely to be a Ford 5,000lb capacity axle)
17000 = 17,000lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
24 = Jacksonville District Code
If something doesn't match up, let me know.
Are you familiar with 2 speed axles?
Old Apr 20, 2021 | 04:36 PM
vintageant's Avatar
vintageant
Excellent! Thank you very much indeed! Imagine a 2-speed rear axle essentially turns a 4 speed into an 8 speed. OK, not quite, but a lower and higher ratio.
Old Apr 20, 2021 | 05:26 PM
85e150's Avatar
85e150
Two speed info including Eaton videos, see post 5:
https://www.ford-trucks.com/forums/1...ml#post9565523
Ridehard1333
Large Truck
Apr 19, 2021 11:33 PM
Greenmonster13
Apr 24, 2016 03:59 PM
Robbgt
2009 - 2014 F150
Nov 12, 2015 07:29 AM
apkarian100
May 26, 2015 08:08 PM
tmullins214
Large Truck
May 4, 2013 02:26 PM
