Thermostat question
Old May 26, 2025 | 11:14 AM
Trash Hauler's Avatar
Trash Hauler
Question Thermostat question
Is anyone running the Mishimoto low temp thermostat and if so have you had any issues with it? I have seen reports of the rubber gasket failing or the thermostat sticking closed, not sure if these were early production problems and have been fixed or not, that’s which I’m asking.
Backstory: 2013 F350, unless I am towing or pulling a good hill, the temps are cool enough that the thermostat doesn’t open. I just took a 2000 mile trip with a light load. Temps were consistently running around 190 degrees which is below the 194 OEM opening point. Maybe my logic is flawed, but I would like the thermostat to open once in a while to circulate the coolant in the block. As a side note, oil and transmission temps were fairly matched, each running 200 degrees plus or minus 3.
Winters get quite cold here so I think the SPE thermostat would keep the engine too cold, that’s why I’m looking at the Mishimoto with the 5 degree difference.
Bob
Old May 26, 2025 | 11:32 AM
speakerfritz's Avatar
speakerfritz
SPE has a kit that will open it sooner
https://www.spemotorsport.com/produc...low-thermostat
Old May 26, 2025 | 01:07 PM
F250_Super_4X4's Avatar
F250_Super_4X4
I have been running the SPE High Flow/low Temp thermostat for about 2 years now and love it. Normal driving I will see 180f oil temps, towing a 14k trailer it may get up to 190f.
Old May 26, 2025 | 01:55 PM
longhaultransport's Avatar
longhaultransport
Aren't there bypass holes that allow coolant to flow without the thermostat being open?
Old May 26, 2025 | 02:46 PM
speakerfritz
very tiny and they are more for air
Old May 26, 2025 | 04:58 PM
Trash Hauler
Thanks for the input so far. I am aware of the SPE Thermostat. Winter temps here are regularly -20F and colder, I think the SPE thermostat would keep the engine, and thus the heater, too cool in the winter. That’s why I’m looking at the Mishimoto which opens 5 degrees cooler than OEM vs the SPE which opens 19 degrees cooler.
But with the problems I have seen about the Mishimoto, I have my concerns.
Fritz, you live in upstate NY correct? I spent a few years there courtesy of Uncle Sam. Are you running the SPE thermostat? Any issues with the heater in cold weather?
Bob
Old May 27, 2025 | 09:40 AM
Overkill2's Avatar
Overkill2
Bob
What's wrong with the OEM thermpstat, especially for a cold winter guy like yourself?
I don't tow, but just daily drive mine.. use the Motorcraft thermostat.
I have to flush my primary system this year and bought a new Motorcraft from Rock Auto. I did buy Bullet Proof Diesel's bigger engine oil cooler because my truck has almost 140k miles and figured it couldn't hurt. Also just ordered SPE's silicone oil cooler hoses along with a few more cooling system items from SPE with their Memorial Day sale.
You having cooling issues or concerns?
Old May 27, 2025 | 09:41 AM
Overkill2's Avatar
Overkill2
Bob
That doesn't really seem that hot Bob...
Old May 27, 2025 | 10:56 AM
Trash Hauler
My truck runs cool, which is a good thing, this is new since a bunch of work was done on the truck last fall. Over the course of my 2000 mile trip last week, the coolant temps ran at 188 to 192 degrees F, monitoring with TorquePro. At those temps, the OEM thermostat never opened, thus the coolant in the block never got exchanged with the coolant in the radiator. Maybe that is not an issue but my thought process is that occasionally circulating the coolant between the radiator and the block is probably a good thing. Given the work that was done on the truck, I guess it is possible that the thermostat is stuck open or not properly installed but I will assume that the diesel shop properly installed it and I did have heat last winter.
Living in a cold environment, I don’t want a really low temp thermostat (like the SPE) but I would like the coolant to circulate. So that brings me back to my question about the Mishimoto thermostat. It should cycle open and closed in the temp range where my truck likes to run. My concern is quality / quality control with those thermostats and I’m hoping someone on the forum can share their experience with the Mishimoto thermostat or can explain where my logic about the closed thermostat is flawed.
Old May 28, 2025 | 12:34 AM
Euroman's Avatar
Euroman
Your thermostat is opening at that lower temperature. Everything looks to be working ok.
Old May 28, 2025 | 08:07 AM
Overkill2's Avatar
Overkill2
I concur with Euroman.
Yesterday on the way home from work, my primary coolant temps bounced from 189 to 196 degrees. Oil temps usually follow the coolant temps, but usually are just below it. Ambient temps were from 73 to 75 degrees. And that was climbing altitude on the way and hills on the roads home.
Today is cooler at 57 deg. When I leave the house today, have a regen to do as truck is at 90%, I'll keep an eye on the primary temps. They do get hotter when air temps are warmer.
wpg_250
Jun 23, 2024 06:50 PM
Strokiner2001
Dec 29, 2021 02:29 PM
John - NNY
Jul 8, 2011 09:31 PM
Diabolic
1983 - 2012 Ranger & B-Series
25
Mar 10, 2004 08:51 PM
wyotommy
15
Mar 3, 2004 09:40 PM
