Nox sensor
Old Mar 18, 2016 | 01:11 PM
jwsrules's Avatar
jwsrules
Nox sensor
Hi my 2012 6.7 with 115000miles recently has Ben throwing a P2000 code which I look up says nox sensor temp. If I drive a lot of Hi way like couple weeks ago went 150 miles after I cleared the code, engine light stayed off whOle time. But if I do my regular about 40 miles hi way then some city driving it comes back on after 60 miles. I called parts stores they can't sell the nox temp senso. Called dealers even though I tell them the code want to put it on diagnosis machine and charge 110pr hr to do that and sensor is 450$. So I'm just wondering if anyone else had issues with this sensor? And if I'm goin to pay that much maybe I be better of saving for a delete of this crap
Thanks
Old Mar 18, 2016 | 02:20 PM
golfmedik's Avatar
golfmedik
Buy one from the dealer and change it yourself since it is out of warranty. Forgot the actual price. But in the $150 range I believe. Look in the tech folder and it will show you where it is. Then take it to Advance Auto or a another parts store and have the clear the code if you don't have a scanner.
Old Mar 18, 2016 | 04:37 PM
Dakster's Avatar
Dakster
It's called a great money maker for the dealer.... Monty's advice is spot on. And there are dealers online that will sell you parts and not expect to make 100% profit on the part too.
Old Mar 18, 2016 | 06:33 PM
jwsrules's Avatar
jwsrules
Hi yeah I Called parts stores around all said it a ford part only. I did find one online for less. But I'm in Canada so it still be after exchange ect close to 400. I have a code reader I have reset it numerous times.
Thanks
Old Mar 19, 2016 | 11:11 AM
golfmedik's Avatar
golfmedik
Order one from one of the supporting FTE dealers on here. Just order one online and do it yourself.
Old Aug 6, 2024 | 06:46 PM
JoeOMarsh's Avatar
JoeOMarsh
3rd Gear
Thanks
Yep I have the same problem after changing the NOx sensor it must be something else and I bet Ford knows what it is.
Old Aug 7, 2024 | 06:26 AM
speakerfritz's Avatar
speakerfritz
Aren’t there there are 2 nox sensors ?
Old Aug 9, 2024 | 11:54 AM
Overkill2's Avatar
Overkill2
Guys in the dry climate areas of the country will be good... but for those of us in the rust belt or close to the ocean I'd imagine, this has to be taken into consideration:
https://www.jteproducts.com/tutorial.html
I'm going to be buying these to have on hand for the various sensors in my truck when it's time for replacement.
American made... they sell on EBay also.
Just FYI...
Old May 28, 2025 | 11:46 PM
JoeOMarsh's Avatar
JoeOMarsh
3rd Gear
No there is only 1 Nox sensor on the 2011 6.7L deisel.
Iceman1777
6.7L Power Stroke Diesel
Aug 14, 2025 02:44 PM
50th ann
2009 - 2014 F150
Jul 21, 2018 01:21 PM
tlawssss
Jun 23, 2012 07:34 PM
court1100f
16
Feb 1, 2011 12:27 PM
gvrangr98
1983 - 2012 Ranger & B-Series
Jun 2, 2008 01:33 PM
