Particulate matter sensor
Old Mar 11, 2026 | 02:26 PM
  #46
kayakingpoodle's Avatar
kayakingpoodle
Originally Posted by JoeUser
I'm not going to bother cleaning the sensor, as the new one arrived a few days ago (just in time for the rain to put the kabosh on dealing with it). After thinking that I already had a sensor socket that would work discovered that it is a standard 22mm socket, and not a 24mm one required for the new NOx sensor, argh! So, I'm expecting the new crowfoot socket plus a 22mm X 24mm flare nut wrench to arrive tomorrow. Meanwhile, I've been soaking the sensor with PB Blaster for the past few days, so hopefully won't have to break out a torch to assist with removing it. Got plenty of anti-seize compound in case it needs replacing again (still kicking myself for not putting some on when installing it in the Banks exhaust pipe).
I'm not really sure just what the Ford engineers were thinking however, tucking that sensor module mount up and above the spare tire, SMH. Anyway, just thought I'd post an update while I'm here on the forum today.
If you're not going to try and save the old sensor you can cut the wires off and use a deep 6 point instead of a flare/crows foot to have a better chance of not rounding the hex off, or use a boxed end preferably a 6 point.
Old Mar 11, 2026 | 03:26 PM
  #47
JoeUser's Avatar
JoeUser
That's my fallback, if using an impact with the crows foot doesn't work out. There's just not a lot of room up there to attach a breaker bar and socket with the large Banks exhaust. Once I can pop the sensor loose then I'll use the flare nut wrench to securely twist it out. In all likelihood the biggest PIA is dealing with dropping the spare enough to reach the sensor and its bolts...
Edit: Well, that wasn't so bad. I reckon repeated sprays of PB Blaster for a few days did the trick, as I was able to tap the flare nut wrench once and broke the collar nut loose. Spread some anti-seize on threads of the new one and easy peasy install. I was surprised the sensor block above the spare tire area was simply held on with plastic fasteners.
The only enhancement I performed was to dab some RTV silicone around the wires and connector for the sensor block. Just to keep dirt and water out of the connector from the back side. Seems like they would've sealed that up when manufacturing the harness, given the sensor block location under the bed.
LoneStarLegend
Mar 30, 2023 12:06 AM
RigCity
May 24, 2022 08:25 AM
Subsailor1127
6.7L Power Stroke Diesel
Apr 9, 2015 03:03 PM
spinningwheel
15
Oct 10, 2013 06:19 PM
jetmech38
Modular V10 (6.8l)
May 7, 2010 09:58 AM
