Onboard "toolbox"
-Glenn
I know the HTSB is still looking into why Ford recalled the ambulance trucks for this issue and not the consumer trucks.
It is a good thing to test verify like the member has posted. The thing about using Torque Pro is that different people used different names for the EGT sensors locations. The EGT 1 location with the Torque Pro Custom PID I use might not be the same as yours?
If you monitor the EGTs with the graph display with Torque Pro, this might give you a better understanding of the locations. From a cold soak by theory the EGT closest to the engine should heat up first.
Also I believe that the Nox sensor should not read like an EGT sensor. EGTs are a RTD device and the Nox/O2 sensors are not and have heater circuits.
I'm not an Expert and I'm guessing. I believe that the new flash reduces the temperature of the active Regen. I don't know if it will change a measage or stop the engine, that is a software thing? If you have to change a EGT it is a hardware thing, I believe that thermal shock is causing the RTD to fail, but it can be that it is just a man made thing breaking.
I have graphed the EGTs and one of them had a noisy signal before the flash and it doen't appear to have one after the flash. I guess time will tell.
11,12,13 and 14.
https://www.ford-trucks.com/forums/1...l#post14665189
also, if you DO get the stop safely NOW message, there should be a code recorded and it will also map to a sensor.
from https://www.ford-trucks.com/forums/1...l#post13833260
bank = 1, sensor = 3, label = 13
Codes;
P0544 - Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1
P0545 - Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546 - Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P2080 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor1
P2081 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1
P2084 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor2
P2085 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2
P20E2 - Exhaust Gas Temperature Sensor 1/2 Correlation Bank 1
P20E3 - Exhaust Gas Temperature Sensor 1/3 Correlation Bank 1
P20E4 - Exhaust Gas Temperature Sensor 2/3 Correlation Bank 1
P242A - Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3
P242B - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor3
P242C - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 3
P242D - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3
P242E - Exhaust Gas Temperature Sensor Circuit Intermittent/Erratic Bank 1Sensor 3
P246E - Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 4)
P2470 - Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 4)
P2471 - Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 4)
P2478 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 1)
P2479 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 2)
P247A - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 3)
P247B - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 4)
Sensor order, 1 is 1st from turbo, 4 is last before tail pipe
I have witnessed several different regen programming parameters with the 6.7. One was in a MY2011 March 2010 build truck, my job 2 December 2010 built - 2011 was slightly different and then it had the Nox sensor recall/reflash where it changed yet again, and now my 2015 behaves differently than the previous trucks and I believe more like the recently reflash for the previous model years...
So is it related to that specific failure? Was it because the old way wasn't EPA compliant? Was it because this is a better way? Who knows. Only the Ford engineer(s) that have made the changes know those answers for real.
On this board we are waiting to see if someone with a 2015 or a re flashed truck has the "stop safely now" EGT issue or not.
