ABS Light
Old Oct 2, 2024 | 12:37 PM
Jasonlion54's Avatar
Jasonlion54
Trailering
ABS Light
Hi All,
I have a 2005 F250 Superduty, 175k miles
My ABS light has been on for some time now. No symptoms when driving, but I haven't tried locking up the brakes yet to test it. Brake fluid reservoir is full. I just replaced the speed sensor on the rear differential. I have an OBDII dongle and use Forscan on my phone, but it doesn't seem to show any codes or any other info from my ABS system. I tried using the code reader at O'Reilly's with the same result.
Any tips or tricks on how to read this code or diagnose the ABS light? Thanks.
Old Oct 2, 2024 | 02:05 PM
Hartwig's Avatar
Hartwig
For some time now, I have also occasionally had the light on in poor road conditions.
I suspect it is due to a rust problem with the front sensors. I'll take a closer look at this in winter.
Does the light disappear when you turn the truck off and restart it?
Old Oct 2, 2024 | 02:12 PM
Jasonlion54
Trailering
When I turn the key to on, engine off, all the dash lights are on. When I start the truck, the ABS light is off for 1-2 seconds, but then immediately lights up and stays on.
Old Oct 2, 2024 | 02:18 PM
Hartwig's Avatar
Hartwig
ok, then there seems to be a permanent issue. In my truck it disappears after restarting (it is still on for the first few wheel rotations, then it goes off...until the next pothole...then it comes on again).
Old Oct 2, 2024 | 04:08 PM
joe blow's Avatar
joe blow
Funny this was posted, I have never had an ABS light on the 20yrs I've owned the truck and yesterday.....ABS light
Haven't looked into it yet.
Old Oct 2, 2024 | 04:49 PM
Brotherbillstruck's Avatar
Brotherbillstruck
I have had the light on a few times. Always seems to be related to mud/standing water. Always goes out after a bit of driving and things dry/clean out.
Old Oct 3, 2024 | 09:28 AM
joe blow's Avatar
joe blow
I cleared it while stationary, and it came back on after restart.
I pulled out and started driving, light goes out. Drove 30 miles yesterday and it never came back on. This morning on the way to work the light is back on......its going to be one of those problems.
Old Oct 3, 2024 | 10:55 AM
Jasonlion54
Trailering
Does anyone know how to read the code?? Seems like such a common problem, there should be a known troubleshooting guide.
Old Oct 10, 2024 | 05:52 AM
Fuzzpuss's Avatar
Fuzzpuss
If you don't have a way to read codes go to Autozone or O'Reilly and they will scan it for free.
Have any of you guys checked your front hubs for play?
Old Oct 10, 2024 | 07:24 AM
Hartwig's Avatar
Hartwig
No hub play here (5730lbs on front axle). Thinking of an rusted sensor seat.
Old Oct 10, 2024 | 10:53 AM
joe blow's Avatar
joe blow
My light went off and stayed off.
Oh well....no light no problem
Old Oct 10, 2024 | 06:03 PM
bismic's Avatar
bismic
At some point, we can ALL identify with that!
Old Oct 10, 2024 | 07:15 PM
tfunk88's Avatar
tfunk88
I have this same issue…ABS dash light comes on sporadically. I thought at one point it was related to hub play, and it might be…but the last few times no detectable play 🤷‍♂️
And also no codes. I read codes with DASHDAQ and also with OBDII-Link with an “enhanced” Ford module that says ABS codes are monitored under powertrain control module. Not sure what’s up.
On second thought I’m pretty sure my left front inner hub seal has a leak as I have a vacuum leak when shifting into 4wd…I wonder if that’s letting moisture in and triggering the light…but still unsure of why no codes.
Old Oct 10, 2024 | 11:17 PM
BLADE35's Avatar
BLADE35
You can work around No DTC to a point
you should be able to ohms test the speed sensor in each unit bearing pull it apart and test where it plugs into main harness /unit bearing pigtail connection
Intermittent Light
i have had intermittent abs light that would go away with restart and randomly reappear
Troubleshooting I found I could trigger the abs light by wiggle test of harness in wheel well area with truck at idle in park
I found that the pins and connectors on aftermarket parts/unit bearings electrical connections we’re not as good as fit as OEM where it connects to truck harness IIRC I just bent the pins to force good contact been good since
Old Oct 11, 2024 | 06:20 AM
TooManyToys.'s Avatar
TooManyToys.
Corrosion at the pins, some rust jacking between the sensor and the hub, and debris on the sensor face can also contribute to this issue. Pulling the sensor out of the hub can be a problem in itself.
Royson12
Jul 5, 2017 10:41 AM
spinella
Jun 22, 2011 01:24 PM
Ohio Ford Farm
1983 - 2012 Ranger & B-Series
Sep 20, 2009 08:30 PM
Little35
1997 - 2003 F150
Jul 23, 2008 04:44 PM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
