Sponsored by: Real Truck
abs light
Old Jun 18, 2011 | 02:16 PM
spinella's Avatar
spinella
abs light
i was coming to a stop this morning and felt something through my brake pedal...kind of like when the abs is working. brakes felt fine afterward, but the abs light went on and is staying on. i checked for trouble codes with my sct x2 and it shows no codes. any idea what happened? why the light is still on? thanks.
Old Jun 18, 2011 | 07:38 PM
spinella's Avatar
spinella
bump....might try to fix this in the morning.
Old Jun 19, 2011 | 04:44 AM
TobiasR.'s Avatar
TobiasR.
Is it possible that your speed sensor works not at all times ?
Check the resistor from the speed sensor ? (rear differential)
cheerio
Old Jun 19, 2011 | 07:20 AM
Lou Braun's Avatar
Lou Braun
You will need to use an ABS capable code reader to find out what tripped the ABS light. It can be as simple as a brake light.
Odds seem to favor the rear ABS sensor, but I'd recommend obtaining the code before playing with that sensor and potentially adding to the problem.
Lou Braun
Old Jun 19, 2011 | 12:29 PM
spinella's Avatar
spinella
will do. thanks guys. speedo is working just fine. is that a symptom of a bad vss?
Old Jun 22, 2011 | 01:24 PM
spinella's Avatar
spinella
follow up....turns out it is a bad abs wheel speed sensor front right,. best price i found was $123
BIGBAND39
Escape & Escape Hybrid
39
Mar 24, 2016 12:23 PM
Beastlyforddude
Feb 16, 2011 01:54 PM
Ohio Ford Farm
1983 - 2012 Ranger & B-Series
Sep 20, 2009 08:30 PM
84-250
15
Jan 9, 2009 03:50 PM
edub32
53
Feb 5, 2006 09:05 AM
