Engine mounts
Old Sep 30, 2024 | 02:18 PM
JRT812's Avatar
JRT812
Engine mounts
Need some help…. I am new to this and never done an engine swap before. Removed the 400 and putting in this 460. The mounts are from JBG and I am having a hard time getting the engine to sit flush. Any tips would be appreciated. The first pics are before the engine is completely lowered and and the second are completely lowered. Thanks!
Old Oct 1, 2024 | 07:33 PM
440 sixpack's Avatar
440 sixpack
I really can't see it very well in those pictures. is there a rubber insulator or are these solids? something doesn't look right.
Old Oct 1, 2024 | 08:07 PM
JRT812's Avatar
JRT812
Thanks for the reply and solid mounts. I’ll try to post better pictures
Old Oct 1, 2024 | 08:19 PM
440 sixpack
Are you really sure you want solids? that's high performance race car stuff.
I'm not sure you're going to get a perfect fit on solids, especially aftermarket ones made for an application that was never stock. it may take some tweaking on your end.
you might consider the Advanced adapters mounts.
Old Oct 1, 2024 | 08:45 PM
JRT812's Avatar
JRT812
To be honest, when purchasing the mounts I was just getting what others have bought after researching everything that I needed for the swap. I wouldn’t say the engine going in it as high performance but heads have been worked and has a 514 stroker kit. Not sure if why the mounts were recommended but I guess I am going to do some modifications to them. Appreciate you responding
Old Oct 1, 2024 | 08:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
As fas as the solid mounts, you are talking about these right? https://shop.broncograveyard.com/197...saAllaEALw_wcB
Are you still using the original motor (400) stands... AKA perches? You might have to swap over to these?
https://shop.broncograveyard.com/Mot...uctinfo/20523/
Did your research say you could use the solid motor mounts with your original 400 stands?
L&L ? https://www.landlproducts.com/list.aspx?m=l&c=3&sc=112
https://www.landlproducts.com/blog/4...-motor-mounts/
FYI https://www.ford-trucks.com/forums/1...or-mounts.html
L & L Engine mounts - Ford Truck Enthusiasts Forums
May 22, 2012
L&L 460 engine swap motor mounts for 71 4x4
Mar 17, 2011
460 engine mounts - Ford Truck Enthusiasts Forums
Aug 23, 2015
L&L 460 engine swap motor mounts for 71 4x4 - Page 2
Mar 17, 201
Old Oct 1, 2024 | 09:27 PM
JRT812's Avatar
JRT812
I just recall needing different mounts and nothing about different perches or anything of that nature. I purchased l&l headers and remember their mounts had issues so I went with JBG. I didn’t really look into about solid mounts but will read up on the attached articles. Thank you for sending them my way
Old Oct 1, 2024 | 10:02 PM
440 sixpack
I would buy some rubber mounts, there's a reason everything uses them.
You shouldn't need new perches the good aftermarket mounts are made to use the existing ones. I did my first 385 serries conversion in the early 80's. at that time we used 390 GT mounts and turned them sideways. they worked just fine and I put a new set in last year when I rebuilt the 429 in it.
Old Oct 1, 2024 | 10:03 PM
77&79F250's Avatar
77&79F250
I seem to sort of remember that you can use the same 351M/400 towers/perches for a 460 swap in. You just have to mod the motor mounts (bolt?) or some thing like that.
Here is a good old read with swap info. https://www.projectbronco.com/
Technical https://www.projectbronco.com/Techni...ical_index.htm
https://www.projectbronco.com/Techni...alling_460.htm
Old Oct 1, 2024 | 10:16 PM
JRT812's Avatar
JRT812
I really appreciate the information
Old Oct 2, 2024 | 05:28 PM
tbear853's Avatar
tbear853
I recall a friend using solid mounts, lost coolant when a chunk of block broke loose around the mount area. Was a BBC in a Camaro.
Winterbeast
Sep 4, 2024 06:47 PM
user 629023
Jul 20, 2021 08:57 PM
Dennis-
Apr 12, 2018 01:34 AM
lucky_thirteen
Offroad & 4x4
48
Nov 29, 2012 04:52 PM
