L&L 460 engine swap motor mounts for 71 4x4
that i do know but these are a factory engine mount from what? i'm not sure but it wasn't a hack job install was clean wondering what mounts they are maybe to help someone else out if they want a 460 install it will give them an idea on what mounts to search for a junk yards or wherever. if you want i can post some pics of the mounts see if anyone can identify them.
I haven't a clue since there was no such thing until 1983.
1973/79 F100/350 460: All these trucks were 2WD / Econoline 460 supports (all 2WD as original) will not work on F100/350's.
1983 was the first year Ford offered a 460 w/4WD and w/a manual trans: F350 only. And because the frame is different, these will not bolt to a 1979 or earlier truck.
There are no 460 4WD factory engine supports (aka towers, stands, perches) to search for prior to 1983, because there aren't any. 1980/82: The 460 was only available in Econolines.
probably 400 mounts made to work?
This is the norm for back in the day. Never ran a factory 460 motor mount. Order my L n L mounts and called it good. Scary simple! I've always ran the 460 over the 400 frame mounts in the later 70's frames in f-150 and f-250. just picked up some 400 mounts yesterday for a 1970 f-250 frame. very similar and will see if they will work in this applicaiton.
What engine do you have in your 79? I'd like to figure out what these are for it would save the 77-79 guys some trouble of buying new aftermarket towers if they can find a set of these the 460 should bolt right in I'll have to look and see if I can find a part # I just got a set of autofab swap mounts for this install should have them soon ill post pics of install when I get them
I don't know at this time what the PO had in there originally, ( I will ask him) but it was swapped out to a 460 from a 1976 Lincoln. From what I can see, the towers in my truck are original FOMOCO. Mine even has the same line retainer, same color! When you get around to swapping engines, check to see if those mounts will fit in your 71. I don't know if there were any frame changes for 4X4's from 70-79 but if they fit, someone can use them.
They may fit only thing is I put them on and could only get 1 top bolt in the other was half a bolt hole off the side bolts didn't even line up to far apart length wise if I remember correctly I'll put the autofab mounts in take some measurements on engine height and how far back it sits then try the stock mounts and see what the difference is might get lucky and only need to make new mounting holes for the stock mounts to work ill let you know when I get the parts
alittle update i got the autofab mounts this week and test fitted them on my frame they fit pretty good the passenger side bolts up great no issues the drivers side is good except you need to remove a factory fuel line clip and the top two holes for the bolts are just alittle off see pic but that's nothing to fix i really like that they use all 6 holes in the side of the frame to bolt up i'm happy with the quality of them big test is when you try bolting the engine in hoping to get to that part in 2 weeks or so heres some pics of them in
white clip needs removed
drivers side top of frame mounts
It will be alittle while before I get the truck done while I do the 460 swap ill also be doing a zf5 trans swap 79 front disc brake Dana 44 rear Dana 60 power steering setup off the 79 I'm in the middle of doing the front and rear 99-04 super duty suspension swap 8" and finish welding in some new door bottoms and rear cab corners one great truck when complete I got to add some pics to my super duty spring swap thread so I will get some pics of the 79 mounts on my frame
BEN WHEELAN
32
12-08-2015 09:36 PM
kcoburn1
11-15-2015 06:29 PM
jack47
08-08-2012 06:29 PM
17witha664x4
02-29-2012 04:04 PM
