I originally used the word block for a lack of a better one, but when it comes down to it what is the spring seat besides a lift block with a radius cut in the top? Anyway like I said, once the hundred and a half comes through for a rebuild kit I oughta be rolling. Hopefully it'll be done before the first of the year
oK guys....lets not start throwin around remarks that we might regret later.....Now...yes coils spacers will work, although i don't know that i'd use them on top of the spring. But finding a longer stud should show to be interesting, i had a hard time finding any different studs when i did my sas.
I just swapped my 81 to the TTB, and, I test fitted the 2wd spring seat on a 4x4 beam, and IIRC, there would still have been acceptable stud engagement with the existing one, I didn't do it though, as I had considerable problems getting the camber even close to fixable with an alignment...
If I think of it, my 2wd front end and a section of 4x4 beam(with the spring pad on it) are sitting in the bed of my F250...
MustangGT221: I just converted my 81, I had a heck of a time getting the nose of the truck to come down to level it with the stock 2wd rear springs with the factory 4x4 2" blocks, I ended up torching the springs(I don't have a transfer case installed yet tho, I'll probably have to swap 'em.) The 2wd axle beams are considerably shorter than the 4wd ones... I guess I'll have to get out the digicam being I have all the parts sitting in the bed of my truck...
when you lower the coil buckets.....you get a peice of square tubing...(or whatever).. to go between the bottom of the frame and the coil bucket....its perfectly fine if you doit this way
Originally posted by 85351ho when you lower the coil buckets.....you get a peice of square tubing...(or whatever).. to go between the bottom of the frame and the coil bucket....its perfectly fine if you doit this way
