Sponsored by: Real Truck
View Poll Results: Do you think it is ok to stack leaf spring lift blocks?
YES
5.80%
NO
94.20%
Multiple Choice Poll. Voters: 69. You may not vote on this poll
Would you stack leaf spring lift blocks?
Old Jan 21, 2007 | 07:36 PM
stevenn1's Avatar
stevenn1
Question Would you stack leaf spring lift blocks?
Do you think it is ok to stack leaf spring lift blocks? (I voted no.)
Basically, your truck already has a stock 2" block between the leaf spring and (rear) axle. You are wanting it to be lifted 2" taller than it already is. Would you add another 2" block to the current 2" block to equal 4" or would you swap out the current 2" block for a 4" block?
Old Jan 21, 2007 | 08:06 PM
savage2211's Avatar
savage2211
No Never!!!
Old Jan 21, 2007 | 08:20 PM
seetwisted's Avatar
seetwisted
Blocks Ba-a-ad.
Old Jan 23, 2007 | 01:22 AM
paul's Avatar
paul
Stacking? Hell No.
Old Jan 23, 2007 | 06:10 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would go to the ford dealer and get the correct 4" block
Old Jan 23, 2007 | 09:26 AM
heidiandmax's Avatar
heidiandmax
Thats a no-no!........never stack blocks.
Old Jan 23, 2007 | 10:39 AM
arctic y block's Avatar
arctic y block
No not unless I had to. In as much as a near 200 mile round trip to Napa I might drill bolt and weld them for off road only.
Old Jan 23, 2007 | 01:59 PM
sglynx1's Avatar
sglynx1
Like this??? Bwa hahahaha, guess I'm gonna die soon huh?
Old Jan 23, 2007 | 02:23 PM
Pocket's Avatar
Pocket
Check lift laws, in some states stacking blocks is illegal.
Old Jan 23, 2007 | 02:28 PM
rrock724's Avatar
rrock724
when I first had my 2K4 SD lifted, they put in 6 inch blocks on top of the stock spacers, I told them I wanted all spring lift but they misundrestood me for some reason and put the blocks in, they didnt last long, I got my springs in in less than 2 weeks and the ride was noticably better.
I would never recommend using blocks period for lifting a truck, I ve always gone with an all spring lift in the past, but some guys dont mind using blocks.
Old Jan 23, 2007 | 03:17 PM
highboy390fe's Avatar
highboy390fe
Blocks are not a bad thing i guess, but thats if you keep them small or factory but never stack them and if you have to weld them together so its one block.
Old Jan 23, 2007 | 05:44 PM
KubotaOrange76
your ujoints will die an early death
Old Jan 23, 2007 | 06:28 PM
sglynx1's Avatar
sglynx1
.........So be it.
Old Jan 23, 2007 | 06:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes - stack the blocks!
Darwin theory at work.
Old Jan 24, 2007 | 12:20 AM
paul's Avatar
paul
The U-Joints will not be the only thing dying an untimely death. The slip yoke will wear prematurely due to the flex of the axle during acceleration and deceleration and will sometimes break due to binding caused by the lift.
