I already have a 6inch suspension lift but not with leafs only shocks and blocks. I was wondering what the outcome would be if I was to put on lift springs.
So... if I put on like a 5.5 inch lift spring in the back and took away the 2 inch blocks would i be able to keep the shocks, and would it be higher. Probably a dumb question.
take out the 2 in rear block and replace the springs rear springs with 5.5 inch lift springs and your truck will sit about 3.5 inches taller, so get 3.5 inch lift springs for the front and your truck will sit level.
How much lift does the front have? You can't really lift a truck with shocks usless you're talking about air-shocks but then you should only be talking about the rear suspension on a Mustang or something
