Sept 2024 All-topic thread
Old Sep 20, 2024 | 01:53 PM
  #106
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Living in an apartment, I don't worry about a bad water heater, or garbage disposal or whatnot. And my truck is so high I can barely reach the engine. LOL Which is why the tools I bought are hardly used. However, if I had no tools here I would feel naked. So I own them just in case I need them for a repair that I can actually do. Even without the disability there is still quite a bit I would not be able to do, but it is nice to save money on the repairs I can do.
Jim
Old Sep 20, 2024 | 02:25 PM
  #107
Fifty150's Avatar
Fifty150
Safeway got me again with tri tip. Easiest thing I do. 500 degree oven. 15 minutes.
Old Sep 20, 2024 | 03:17 PM
  #108
Modoc's Avatar
Modoc
Still working on leftovers in the refrigerator. Today’s brunch was chopped up fajitas in an omelette with San Francisco style Sour Dough toast.
Old Sep 20, 2024 | 03:20 PM
  #109
Fifty150's Avatar
Fifty150
Looks awesome. That's real skill with the omelette. Timing, temperature control, and a controlled flip without breaking it. You did a perfect job.
Old Sep 20, 2024 | 03:24 PM
  #110
Modoc's Avatar
Modoc
@Fifty150 , thanks for the compliment! Too bad the back side is hidden A couple things that I’ve learned are to warm the filling separately and that High is not the only setting on a stove. 🤣
Old Sep 21, 2024 | 09:36 AM
  #111
GlueGuy's Avatar
GlueGuy
​​​​​​I am not a mechanic. My cars are running. Just getting something I always wanted. Which I literally waited decades to buy. I do know that the first job I do, will pay for them. If I change my thermostat, an easy job, it will save maybe an hour or two on mechanic labor. I've paid for all my tools that way. One oil change and you have paid for the wrench, jack, and so on. The truth is that I am a tool junkie. I own things like a pole saw. Why pay hundreds for tree trimming, when I can buy a saw? Why pay hundreds to change a hot water heater, or stove, when I can do it with a few wrenches that only cost a few dollars? I did buy a sewer jet for about a hundred, to save a few thousand on hiring a plumber . My neighbor paid $2,400 for a plumber to run a sewer jet . I'm not doing engines and transmissions. Just very simple jobs. The problem is accumulating a pile of tools, that aren't being used every day.
Hundreds for a water heater?!?
Our water heater died Thursday. I checked it and the pilot would not light. Went to HD and they connected me with a local service company, who came out and replaced it. They did a bang-up job; replaced the copper flex lines with stainless, replaced all the ball valves, the gas valve, moved the sediment trap to comply with new code requirements, installed an expansion tank (also a newer code requirement), and wrapped all the pipes in insulation. The job took 4 hours from a skilled technician, plus (I'm guessing) about 3 hours travel time. Total came to $4,350. Now THAT'S a spicy meatball. The heater itself was about $600-800.
We had hot water again by noon Friday.
Old Sep 21, 2024 | 09:42 AM
  #112
Fat Diesel's Avatar
Fat Diesel
Dang. I put a new electric water heater in my ADU last weekend. I may be a slum-lord, but I at least have to provide hot water for the $1600/mo I demand.
The heater was about $500 and the new hoses, fittings, and a new water filter was about $150. Electrics are sooo much easier to replace. It took less than an hour.
Old Sep 21, 2024 | 10:58 AM
  #113
Fifty150's Avatar
Fifty150
Wow! The guy did quite a bit of work. But still. Wow. That's a lot of money.
When I replaced my water heater, I installed new water and gas lines. Supposedly, you use new lines, so that you have new fittings, which will seal better. Nothing too complicated. Just a couple of cheap wrenches. Drained the old water heater. Disconnected the water and gas. Swap the old with the the new. Reverse the process. No permit. No code inspection. Everything worked just like before.
I forget what the water heater costs. It was just the common cheap floor model at Lowe's. And the connection kits hanging on the display next to the appliance area. I personally think that it's a scam to sell new water and gas lines with every appliance. But they are cheap enough that I do it.
The hardest part was setting the temperature. I don't want the hottest water, which scalds. Maybe other people do want that.
Old Sep 21, 2024 | 11:05 AM
  #114
Fifty150's Avatar
Fifty150
For me, the actual work was less than an hour. . Wrench off water and gas. Move old tank out. Move new tank in. Wrench on water and gas. Turn on.
If I had to pay someone, the labor wouldn't cost more than the water heater.
Another job where a few cheap wrenches saved a little money.
I am assuming that I did okay. None of the lines are leaking. My water is hot.
Old Sep 21, 2024 | 12:13 PM
  #115
Nighteyez's Avatar
Nighteyez
At this apartment complex there is one water heater for 54 units. It is located in the building by the empty swimming pool. Needless to say, it takes forever to get hot water in my apartment unless some else had just used it.
Jim
Old Sep 21, 2024 | 09:37 PM
  #116
Fifty150's Avatar
Fifty150
Lucky Stores got me. Took my money. They know a sucker when they see one. The sucker is me. They sold me on the pork. Even though I know better. The worst part is that I may go back for more
Old Sep 21, 2024 | 11:02 PM
  #117
Nighteyez's Avatar
Nighteyez
Looks good enough to eat.
Jim
Old Sep 22, 2024 | 01:41 AM
  #118
Fifty150's Avatar
Fifty150
"Are you crazy? You went through all that trouble, to make instant noodle?"
Yes. That's why I roasted pork. To make chasu ramen.
Old Sep 22, 2024 | 10:21 AM
  #119
GlueGuy's Avatar
GlueGuy
I fixed a (Santa Maria style) tri tip last night. I think it was one of the ones Safeway had on sale. That said, I used the BBQ, and seared it for 4 minutes, turned down the heat (~~ 350) and slow-cooked it on indirect heat for about 45 minutes. It was very flavorful, and I did not take pictures.
Old Sep 22, 2024 | 10:43 AM
  #120
Tim Young's Avatar
Tim Young
Good morning Nor Cal food people
